speed11
09-11-06, 12:22 PM
I looking to purchase a nice '05-'06 STS v8 car. I'm wanting the NAV, sunroof etc..
I'm in the process of selling my two collector Buicks in order to help fund this. (wife said I had to) I'm not big on car payments.
Anyway in a pefect world someone would take my Buicks on trade. If anyine is interested here is the info on them.
One only has 34k orginal miles Navy Blue/blue all stock except exhaust,shocks,radio/cd player(I still have all original parts) and GNX dash. $16,500
The other is a 1987 Buick Turbo -T that I purchased from the original owner. I have all the original paper work /brochures/window sticker etc... the car faxed with 92k miles on it but it had a complete rebuild/ build up about 5000 miles ago. Mods: A lot of things under the hood have been chromed or ceramic coated; including the headers and cross over pipe, valve covers, down pipe, chrome t-shield and pipes etc.
3.8 block .030 over, balanced
block girdle
Steel main caps
ARP fasteners & cylinder head studs
thermal coated TRW pistons
lunati 200/200 cam parkerized
TRW springs
ported heads w/larger valves
ported matched intake
PTE 60 turbo with turbo saver
55lb injectors
ceramic coated factory headers
Terry Houston down pipe ceramic coated
test pipe to dual flow master w/ dump
Volt booster
High performance in tank fuel pump with hot wire
Mark Jackson stretched notched intercooler
Conley cold air package w/14 inch K& N filter
Trans: factory 2004r with high performance rebuild , Art Carr 3200 stall 9" lock-up converter and Stage Right trans brake w/ BM trans cooler installed an additional drain plug for servicing the trans.)
Drive shaft loop
rear end has girdle w/ about 40,000 miles on it w/drain plug.
KB Frame braces behind seat and up front
Replaced all GNX frame bushings that were missing
All stainless steel brake lines
New brakes w/ new Kirbin Accumulator
New tires
Morso Three way adjustable race shocks
Air bag in right rear spring
pinion snubber
Interior: Grey
Custom instrument cluster by Charge Air Systems / White Auto Meter phantom gauges
GNX style w/ red back light
Stock radio
Panasonic speakers
A/C was converted to R134A- 2003
Exterior
Paint is good- repainted
Interior is in excellent condition.
Excellent head liner and sun visors.
appraisal
No rust & No undercoating
Price reduced to $14,500
Both are excellent examples
I can email pics or come buy and take a look. I live in SW OKC just off I-44.
Bwlong@cox.net (Bwlong@cox.net)
block girdle
Steel main caps
TRW springs
55lb injectors
Volt booster
Drive shaft loop
New tires
pinion snubber
Interior: Grey
Stock radio
Panasonic speakers
Exterior
appraisal
