View Full Version : moving the battery to the trunk
DeVillish
01-13-03, 05:11 PM
i wana move the battery to the trunk, its in the way of my cone filter idea, and i'd rahter have like 10lbs in the trunk insted of up front, that V8 is enough wieght up there. So what all do i need to get/do?
jeff___H
01-13-03, 05:30 PM
Try summitracing.com or jegs.com for a battery relocation kit.
DeVillish
01-13-03, 05:49 PM
cool, thanks. 42 bucks isnt that bad.
Mad'lac
01-13-03, 05:51 PM
Maybe now would be a perfect time to put in a Optima battery. I heard that even if they crack they don't leak. Might be nice to have that in the trunk.
BeelzeBob
01-13-03, 10:43 PM
Good idea with that Optima.. What IS the weight ratio on these cars? I mean from front to back?
DeVillish
01-13-03, 11:36 PM
thats a good question, one that i really wana know. And how muc do those optima batteries go for?
Scrapyard
01-21-03, 12:06 AM
Optima, roughly $100. Educated guess 57/43 weight bias. Word of advise. Make sure the wire runing off the altanator to the positive post of the battery is at least 10 gaw wire. I had a charging problem with my 85 FW when I did that mod. If you buy the kit from Jegs you should be ok. I built mine from scratch so I had problems. Live and learn I guess.
Andrew60SP
01-21-03, 03:15 AM
A search turned up the following:
current model STS: 62/38
DTS: 61/39.
CTS: 52/48
'67 Eldorado: 58/42
I would imagine most FWD Caddy's being at least 60/40.
Katshot
01-21-03, 07:53 AM
Hey Shaun,
Good to see you here ;)
The Optima is a great battery for specific applications. Also remember that the Optima can be mounted in any orientation (sideways, on-end, etc.). Also, cable routing is CRITICAL for safety as well as durability.
