: 2006 CTS-V Shift Knob Removal
besito27
09-02-06, 10:53 AM
I have pulled, and pulled, and pulled, and no go, the shift knob won't come off. Am I a girlie-man??:confused: I feel like any harder and the whole transmission will be on top of the dash board. Any other "tricks" to get this thing off? I checked the Cadillac CTS / CTS-V and STS / STS-V Frequently Asked Questions (FAQ) (http://www.cadillacfaq.com) answer page already. The corvette instructions noted there mention a "key" thats needs removal; that doesn't apply to ours, right? Once again, thanks for your help. (Maybe I'll bring my friends Hummer over and winch it off.................)
StealthV
09-02-06, 11:12 AM
CTS-CTS-V FAQ: How Can I remove the Shift Knob (http://www.cadillacfaq.com/faq/answers/sknob.html)
Push forward at the top of the knob while pulling up a little. It's more important to put effort into the forward pushing to twist/rock the knob at its base than the amount of up force.
urbanski
09-02-06, 11:31 AM
in the 3-4 times i tried to do this....following the FAQ....never been able to get it off.
guess i'm a girlie-man
besito27
09-02-06, 12:35 PM
First of all, StealthV, thank you for the !CAGS Elim. Easy hook-up and works great. Now, back to the knob. I'm actually afraid to either bust my hand or break something in the car. I've put that much forward/upward pressure on the shifter. 06's do anything different with the installation? I think its glued in with epoxy!!!! Guess I need to form a girlie-man club..........
CTS-V Racing
09-02-06, 12:46 PM
Sounds like we need some more input from the UUC mod people. All of them must have gone through this step :worship: (no girlie-men among them I guess). I am going to do my UUC upgrade this weekend, so any additional input would be welcome. I also noticed an aftermarket shift knob in one of the pics. Anyone know who makes them and how they attach with this notched push on shift lever?
sotxmike
09-02-06, 01:53 PM
I had no problem getting the stock knob off for the UUC install. Now I can't get the UUC off no matter how hard I try :confused: .
KTSwanson
09-02-06, 01:55 PM
See http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum/77476-how-do-you-get-stock-shifter.html?highlight=shift+knob+removal
Koooop
09-03-06, 10:06 AM
I had mine put in (I'm a girlie man), the mechanic said it was a bittch! Hammers, screw drivers, prybar...The knob got all messed up! He sat it in the sun and the rapping shrank to normal. Apparently he spent an hour trying to get it off.
2004ctsv
09-03-06, 10:34 AM
You guys aren't girlie-men - it's all technique
:jerkit:
I rest my case
nikon
09-03-06, 12:18 PM
well, for me everytime I shifted a little too hard on my 1-2's my knob popped off...I too originally tried doing it the way the instructions say with no luck, so I put the car in 2nd and pull back with a little jolt...and up it comes, easy as pie...might wanna try that, because no matter what I cannot get mine to come off by pushing forward.
Cadispeedster
02-27-13, 11:27 PM
Ok... so what gives with mine??? Did I pull too hard!? lol
Seems I can put it back on and try the quick pull / jolt method...
Any other tips??
Manofmetal01
02-27-13, 11:52 PM
...did you pull so hard your seperated your core?!?! I found pull it into second and pull up at the same time. Its hust a bit of a plastic clip kind of deal inside the knob
Cadispeedster
02-28-13, 12:04 AM
Yeah guess so. It seems to go back on fine, nothing screwed up, is it?? lol... too much manly man here...
Any gear I put it into, try to put a "push forward or back" pressure, and I try to twist a bit. It will still pop out from this core base.
SevillianSTS
02-28-13, 07:07 AM
twisting back and forth while pulling up did it for me. I recommend releasing the bezel before so you don't break tabs off.
I removed a brand new knob with minimal effort.
HAMSTAR
02-28-13, 07:19 AM
Hulk much?
Cadispeedster
02-28-13, 10:56 AM
hmm, yeah still the core I guess breaks... maybe I'll try to hook it up in a vice somehow to not damage it...
Hulk much?
I'm actually an athletic type of guy, more on the skinny side... lol
Koooop
02-28-13, 03:49 PM
Don't forget to throw the factory hunk of poo shift knob in the trash when it comes off.
Cadispeedster
03-01-13, 12:38 PM
It won't come off... lol...
HAMSTAR
03-01-13, 12:40 PM
Doesn't PISNUOFF buy them as cores?
Manofmetal01
03-01-13, 01:31 PM
I think the hole in the side of your core is for a set screw, I could be wrong, I didnt really look that hard as I didnt go hulk on it and tear it in two haha. Maybe you can slip it back on and tighten the set screw..if it is a set screw.
Im not sure what else to do in your situation...is it still under warranty? Mayne have a dealership replace it and start over?
Yes. Buys your core back from you buy refunding from your original payment to him.
WesH8398
03-01-13, 02:56 PM
Twist it a bit, clockwise and counterclockwise, while pulling up. Make sure the bezel is already released or you'll break all the tabs. Might wanna open your sunroof so you don't put your shifter through it once it finally comes off too. lol
Manofmetal01
03-01-13, 03:53 PM
104549
P-Funk
03-01-13, 03:59 PM
No matter what I tried, I couldn't get the knob off of my shifter (even had multiple people try different times and at the same time). I just grabbed a Dremel and went to town on it as I was replacing it with a V2 knob and didn't care if the stock knob got messed up. Just be careful not to go too deep and cut into the shifter itself (I went slightly too deep once and left a small "scratch" on it, but nothing that would cause any issue).
Cadispeedster
03-01-13, 04:14 PM
104549
Yeah any upward pulling, and it's like the core just slides out... I guess some knobs are in pressured in there tighter than others...
Is there a set screw in there? maybe I'll have to tighten it.
Think I'm going to screw a hole in the other side and slide a piece of steal in there. Trying not to damage anything including the stock knob. I think removing the whole shifter assembly will be too much for this project.
WesH8398
03-01-13, 04:29 PM
There was definitely no set screw in mine.
Just twist it (while pulling up). I had to twist mine to get it off, and its back on there just fine now. Warnings are there because it COULD damage it. If you're reasonable with it, it should be fine though. No more risk than doing what you're doing now anyway.
Longsnapper52
03-04-13, 02:43 PM
I might have discovered the secret here....Or just gotten lucky. I tried all of the pulling techniques and damn near destroyed my shift knob from pulling up so hard. I gave up and thought to myself, why not try PUSHING/LIFTING instead of pulling. I lifted the boot cover grabbed the shifter lever and lifted up...It popped right off with very little effort.
http://i833.photobucket.com/albums/zz255/longsnapper52/Car%20Pics/A0EC0803-C1F9-4F1C-9EFD-28859F4A55C1-3415-000001F3BC47EFFD.jpg
Koooop
03-04-13, 10:45 PM
And now that you've done that, get a properly shaped, weighted shift knob and a good shifter. The stock set up is crap.
Cadispeedster
03-11-13, 07:19 PM
And perfecto... kinda the same concept, thanks! and worked great... Being mine was tore apart lol I just had another party hold the other side and pull... Seems the trick was the very gradual twist back and forth and like the first time having sex, you can feel it juuuuuust start to slip... lol and JENGA! Popped right off.
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-appearance/281546-wtb-cts-v-shift-knob.html#post3248710
gatesjeff33
04-22-16, 12:09 PM
I tried twisting it off at first and I think I broke something internally on the knob. It twists freely and it was a breeze pulling it off once I figured out that's how it's supposed to be removed.
Any ideas on how to get it to not twist? I'm not sure if I should epoxy the knob on or not...
How much does a new v1 or v2 knob cost?
thebigjimsho
04-22-16, 06:06 PM
When I bought my V2 knob from Lindsay, it was around $100. Maybe a little more...
AAIIIC
06-07-17, 08:10 PM
Old thread, I know, but this is one of those things that has been a challenge from the beginning. I was able to get the stock shift knob off the stock lever without having an aneurysm by twisting a bit as I pulled up (as recommended a couple of times in this thread). Well, I installed a UUC shift lever years ago and with that shifter I cannot get the frickin' knob to come off. Over the years the shifter has developed some play, so it's time to replace it all, but I can't do that if I can't get the damn knob to release! I was just fighting with it outside, trying the twisting while pulling trick, heard a "pop", and now the thing will spin pretty freely. Didn't help the knob actually come off, of course! :mad2:
I may just cut this damn thing off and replace it with a V2 knob, or maybe a Raceseng knob.
jmil1974
06-09-17, 11:42 AM
Just make sure to not be pulling towards your face or the sunroof...just sayin'.
07cadv
06-13-17, 05:46 AM
I have had mine on and off while I was changing the shifter, rebuilding trans, etc. One day it decided to not want to come off. I was already planning on installing a TWM Performance weighted shifter so it was not a big deal when I started cutting it off. It refused to come off the last time I needed it to. Hated to destroy it but didn't have a choice.
AAIIIC
06-13-17, 06:59 AM
So how did you actually cut it off? I don't know where on the knob to cut in order to get it free.
07cadv
06-13-17, 08:48 PM
I pried with screwdrivers, etc. and had to use a saw to cut some of it away. I think I have some pics somewhere. Let me look for them.
AAIIIC
06-13-17, 09:26 PM
No worries, just came in from hacking the damn thing apart. Hacksaw + bigass screwdriver to pry things apart. :p
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/Dress%20Up%20Mods/Interior/shift%20knob%20PITA1.jpg
Even after cutting the majority of the knob away, the base of it was still stuck on the shaft, as you can see above. I think when I "broke" the knob the other day (such that it would spin on the shift lever), I must have broken whatever holds the external part of the knob to that inner locking part. I then sliced into that, pried off a piece, and then the little metal clip (which is what actually locks the knob in place) slid out of the slot. What a frickin' mess!
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/Dress%20Up%20Mods/Interior/shift%20knob%20PITA2.jpg
The metal square you can see in the first pic is the top of that metal clip, so in the second pic you can see the actual shift lever because the clip is in my hand.
I ordered a suede V2 knob from Luke @ Lindsay today, so I felt free to demolish the existing knob. :) Should pick up the new knob tomorrow or Thursday. I've got one of the modified Hurst shifters to install, hopefully I can knock that out this weekend.
07cadv
06-14-17, 12:05 AM
Yep.....looks identical to my mess. Took quite a while as well. Tough bugger it was.......
