View Full Version : help identifying parts and removing wire harness
denscor
09-01-06, 11:02 PM
I have a 1995 Seville STS on top of the throttle body is three vacuum ports ! The ports are cracked so I need a new one what is it called? (it comes out of the throttle body)My local dealership has no clue what it is! A Part number would be great also!! Ok I also need help finding out were to unhook the harness that goes into the fire wall to the computer so I can drop the motor? Tried the top nothing but airbag, bottom heater ducks,tried removing glove box took 4 screws out still will not come out! I'm lost!!! help me!!!!!!!!!!!!!
Ranger
09-01-06, 11:55 PM
Check the Tech Tips section for the parts list. It might be there.
zonie77
09-02-06, 12:19 AM
I think it's more than 4 screws. You have to disco the harness at the computer.
chance_b
09-05-06, 09:33 AM
Shouldn't be much of a difference between the '94 and '95, so here's what I had to do..
Under the hood, where the wiring passes through the firewall there are 2 small screws holding it in place. Remove those,
Inside car, passenger side.. under the glovebox was a plastic cover with 3 screws I had to remove, also with a small harness on the other side for a light - take screws out, unhook harness.
The computer was located up in a hard to see area under the dash, mounted against the firewall. I had to pull back the carpet a bit to access it all (and had to pop out some trim to pull back the carpet). Once under, the wiring divided up to about 5 or so harnesses, about 3 going to the computer and the others going to another unit. There was also a vacuum line amidst it all. I unhooked everything (it's already color coded I think so no worries).
Between underdash and underhood, feed/pull the wiring out through the firewall, making sure not to snag the harnesses on anything.
Hope this helped!
JimLucky
09-07-06, 12:23 AM
I know the vacume line part you are talking about on the throttle body mine was cracked also.The parts department had to show a digital picture I took of the vacume line harnes and pass it around to the mechs at the dealership.I had to order the whole harnes to get the part I needed and it also came with the Map sensor installed in the harnes its well worth geting the whole harnes.
Hold on and I find the #
OK Keep in mind this part # was for a 93 eldo N* vin 9
Description: Harnes A, part #3535716
Price $95
denscor
09-07-06, 09:46 AM
thanks that is what i need!!
eldorado1
09-07-06, 01:14 PM
#3535716 is the part number for the whole engine wiring harness? Or just to the intake manifold? $95 seems too cheap...
I might have what you need... I'm not sure I understand though... The little rubber boot thing on top of the throttle body? Or is that something different?
JimLucky
09-07-06, 03:15 PM
The complete vacume harnes with rubber boot to top of throttle was $95 wich
included MAP sensor installed on the vacume harnes.
eldorado1
09-08-06, 05:46 AM
ahh, I see... Never heard of a "vacuum harness" before!
denscor
09-08-06, 06:01 AM
Yes its the little rubber piece it has three ports in it with hoses attached to it on top of throttle body. let me know if you have this i will try to get pic today its off car as i'm dropping the motor.
eldorado1
09-08-06, 09:06 AM
just checked, and mine has a split on one of the ports too... I can take a pic if you want, it might be in better shape than your current one?
JimLucky
09-15-06, 11:32 AM
http://i5.tinypic.com/11w4huf.jpg
