View Full Version : Changing the fuel filter
peteypablo
02-16-04, 12:38 PM
What's the process of changing the fuel filter on a 1995 DeVille North*? Do you have to relieve the pressure? Thanx.
BeelzeBob
02-16-04, 03:23 PM
You don't have to release the system pressure but you'll get a bit of a spray of fuel from the filter connections if you don't.
It is very easy to bleed the system pressure down, though. Just go under the hood and look at the fuel rail and find the shraeder valve fitting on the rail, take the cap off, depress the schraeder valve stem with a rag over the top of it to soak up the fuel. It only takes a moment to release all the pressure.
peteypablo
02-16-04, 11:26 PM
Thanx.
