View Full Version : any known issues on 2000 catera?
CadiJeff
08-28-06, 11:37 PM
Just what the title says, looking at 2000 catera with 137000 mi just curious what to look at.
thanks
Vesicant
08-28-06, 11:46 PM
thanks
Not really... the 2000 was when most things were fixed. Past 100k a tuneup is due for the Catera.
EBTCM may go bad, the heater coolant control valve can crack and leak... shouldnt have to worry about the oil cooler. Has it had its timing belt, tensioners and waterpump changed? 100+ miles is time for it to be replaced per maintenance requirements. Oil in the sparkplug boots or dripping down on bellhousing = needs a valvecover gasket or both. Look for abnormal tyre wear if any. Make sure sport mode works and the transmission shifts fine.
