View Full Version : Transmission thud
cynic
08-26-06, 07:18 PM
If I let off the gas just before my cat goes into third gear and then reapply the gas, I get the "you need a new transmission" thud. Has anyone tried the anti-slip snake oil they sell at autozone? Anyone know where I can find a new tranny (2000 sport)?
cynic
08-27-06, 12:24 PM
Anyone ever try this for their slipping tranny?
Lucas Transmission Fix stops automatic transmission slippage (http://lucasoil.hodgsoncorp.com/slipping_transmission.htm)
carate
08-27-06, 12:31 PM
Have the same problem with my 97. Started when the battery died - must have screwed up the solenoids. I'm wondering if just changing the 2-3 solenoid will solve the problem - the manual shows it can be done by just removing the oil pan & filter. It may also involve the Band Control Solenoid - which can also be changed at filter change time. Mine got a little better when the fluid & filter were changed, but it is representing itself.
Anyone had success with changing any of the solenoids?
Hoosier
08-28-06, 11:06 AM
What is the procedure for the Lucas product? Do you mix this in with the transmission fluid?
Kcryan
08-28-06, 04:51 PM
Sure do, dont use it on good transmissions, but on one thats on its way out, use it, it might help, might not, cant hurt
inconnu
08-28-06, 05:18 PM
I dont think these snake oils work,tried it on my old car didnt do a damn bit,if the tranny is shot it is shot,there is no two ways about it,save your 15 bucks.Just my point of view.
