: Help installing camshafts
brown1904
08-25-06, 08:11 PM
Hello Everyone I have just recently bought a 1996 Seville STS off ebay for $1200.00. I did not do my homework before buying,seller said engine had blown headgasket. Engine was already torn apart. I am trying to stay on a low budget with this car, what I would like to know is 1) what are the torque specs and the sequence for torquing them are? 2) what is the proper way to tighten down the cams, and the torque values for them? Any info would be greatly apprec.
CadillacSTS42005
08-25-06, 09:47 PM
buy a factory service manual for the car your gonna need it for that porject....
zonie77
08-25-06, 10:18 PM
You really should buy the FSM. There is enough to reference that it's pretty hard for someone to give you everything you'll need. Check EBAY. We used manuals a year off and they covered everything we needed.
I think 96-98 are very similar. Someone who knows for sure can chime in.
Depending on where you live the public library may have Alldata access. I know Phoenix and San Diego do.
Some things have been covered in threads. Cam timing and head torque among them. You can search and find those threads.
You probably do not have to do anything with the valves or cams. Leave the heads alone unless you see something obvious. The N* has really good heads, they don't warp or burn valves.
brown1904
08-25-06, 10:42 PM
Zonie77 Thanks for responding I was hoping to hear from you,I have read a lot of your threads. Do you think the heads need to be checked for cracks and milled for warpage? The gasket blew on the back side between the first and second cyl from left to right. Thanks
zonie77
08-26-06, 10:23 AM
As I said, unless you see something obvious they should be OK. The majority of guys who did their own did not do anything to the heads except clean the gasket surfaces.
dkozloski
08-26-06, 11:20 AM
Don't use Scotch Brite pads for anything to do with machinery. They are the worst possible contamination.
davesdeville
08-28-06, 03:16 AM
I'd just check the gasket mating surface with a good straightedge and run with it.
brown1904
08-28-06, 08:02 AM
Does anyone know the sequence to torque the heads to?
davesdeville
08-29-06, 05:47 AM
This is why an FSM can come in handy... if nobody else replies I will take a look tomorrow (although mine's a 95 there *should* not be a difference,) my info is at my friends house/garage.
zonie77
08-29-06, 07:12 PM
The FSM says 22ft/lb + 60deg + 60deg + 60deg.
That's 22ft/lbs plus 180 degrees in 3 steps. I think that was updated to a slightly higher figure though.
Mark the bolts at the 22 ft/lb step so you can verify the turns. Use a sharpie/marker.
brown1904
08-30-06, 12:53 PM
Thanks for your help!!!!!
zonie77
08-30-06, 07:31 PM
Keep us updated of your progress. Where are you located in TN?
brown1904
08-31-06, 02:28 PM
I live about 30 min North of Nashville neaKy line off of I-65. I have a tool & die maker from my work coming 9/5/06 to install inserts. Will keep you guys posted.
zonie77
08-31-06, 04:13 PM
I did Power Tour last year, stopped in Nashville. Nice country.
We were gonna go back there this summer but lotta things came up.
