dom1979
08-23-06, 11:49 PM
I just ordered a set of divino stamina rims 24" x 10" for my 04 ext and the said i should use a 285/40/24 tire is the 285 part right?
| View Full Version : tire size for 24's dom1979 08-23-06, 11:49 PM I just ordered a set of divino stamina rims 24" x 10" for my 04 ext and the said i should use a 285/40/24 tire is the 285 part right? CadillacGrillz 08-23-06, 11:54 PM no the right size everyone uses is 305/35/24 EXTadic 08-24-06, 01:00 AM :yeah: dom1979 08-24-06, 08:48 AM Thanks will 305/40/24 work if i dont lower it for a better ride? jrs05caddyext 08-24-06, 09:49 AM I would go with 305/35/24 DLE 08-24-06, 12:33 PM I got 305/35/24s on mine, and i love it. :thumbsup: 05 Cadillac Escalade 08-24-06, 04:44 PM Thanks will 305/40/24 work if i dont lower it for a better ride? I believe you will have rubbing issues with this series tire. The highest you should probably go with is 305/35/24 which is very sufficient. Many members say that the 35 series tires feel just like stock. Thanks. EXTadic 08-24-06, 06:08 PM Other than a bit of "groove steer" or railroading, which is normal with large wheels.The 35 series really do feel like stock. I have P-zero's and I think the ride/handling is superior. DLE 08-25-06, 02:53 PM Stick with 35 series, because I have the 35s and it does rub a little bit on the front driver side plastic, but i trimmed that and now its gone. So I would think the 40 series would rub even more. RedGalant2k1 08-25-06, 09:49 PM 285/40-24s is what I recommend. CadillacGrillz 08-26-06, 12:36 PM i had 40 before and it rubbed big time so i went on 35 my recomendation from experience manny5700 03-20-07, 01:37 PM I've heard 295/35/24 is good too. The differenece in a 305 vs. a 295 is minscule. We'll see when I throw mine on in few more weeks. widowdaballa 05-22-07, 09:57 PM I just put some 24" rims with 305/35/24 tires and they DO in fact rub a bit when turning. Can anyone explain how exactly they got rid of that rubbing? I heard that with some zip ties, another person said that they cut some of the wheel well off. I want to know exactly how it was done, IF it can be done by oneself. This is on an '04 EXT by the way :) RichieRich 05-23-07, 09:42 AM Go with the 35 series... I have Giovanna's with 305/35/24 Pirelli's & they did rub but only when making very hard turns, either right or left... I did the trim & zip tie thing & the rubbing is 99% gone... The only time they rub now is when I'm backing out of a driveway to the street & there's that point where you turn the wheels & go from driveway to street, but if I back straight out they won't rub at all. DLE 05-23-07, 10:17 AM I just put some 24" rims with 305/35/24 tires and they DO in fact rub a bit when turning. Can anyone explain how exactly they got rid of that rubbing? I heard that with some zip ties, another person said that they cut some of the wheel well off. I want to know exactly how it was done, IF it can be done by oneself. This is on an '04 EXT by the way :) Do a search on "rub" or "rubbing".. Lots of info and pics will come up. :thumbsup: | |
