View Full Version : Replacing stock speakers
cadillaceldoradoetc
04-01-03, 09:43 AM
I want to replace all the stock speakers and upgrade, I was wondering if anyone has done this and what kind of speakers they used, which would be good, which should I avoid. Any help would be appreciated. Thanks
Brandon
BUILDINGCTSAMG
04-01-03, 03:09 PM
If you can afford them try to get rockford fosgate audiophiles they are excellent. Also super high end is focals and alpines are ok. Use crutchfield.com if your a do it yourselfer.
cadillaceldoradoetc
04-01-03, 03:10 PM
BUILDINGCTSAMG,
thanks Ill definately use this info.
jerseyMan
04-02-03, 10:50 AM
Check out the JL Audio line of speakers. I installed a 10" sub-woofer (10 IB 40) with a JL Audio 250/1 amp...it improved the bass response tremendously on my STS.
I had JL 5"speakers and tweeters, and 10" sub-woofer wedge installed in my son's Prelude recently - he loves it!
Good luck.
cadillaceldoradoetc
04-02-03, 10:53 AM
Good luck.
Thanks, btw, where did you put the amp? did you install everything yourself?
Brandon
jerseyMan
04-02-03, 11:16 AM
The amp is mounted in the trunk (pic available soon if you are intersted), attached physically to the back of the rear seat - takes up very little room. I had the work done (along with the complete head unit/speaker system for the Prelude) professionally - it wasn't worth trying to do it myself since it would only have been a modest savings.
jerseyMan
04-09-03, 05:16 PM
Amp photo's are up - check out my web page (page # 3). It takes up very little space, and wiring is not even noticeable.
