: Fan fuse
08-20-06, 08:37 PM
I am having a problem with the mini fuse blowing for the fans. its a 95 STS and the fuse only blows when u start driving the car. U can replace the fuse, let it idle and everything is fine, but as soon as you put load on the motor it pops.
I tried unplugging one fan at a time to see if it was the fan but no luck, still blows.
I tried switching around the relays, they seem to be ok because the fans actually come on and off.
Any idea on what else i can try?
08-20-06, 08:43 PM
Are you sure you're using the right amperage rating fuse?
