TheCaddyKidd
08-09-06, 05:58 PM
ok so i go in the garage to work on my truck and see there is a chip on the door.. by the chip are some light scratches and some smudging like someone rubbed up against it with something.. anyway i am very anal and this chip is really annoying me.. and the worst part is i cant even tell who did it.. anyway.. i was to have it painted but i know that white diamond is the hardest color to match.. my dad did my grille but you tell the paint is off alittle.. wondering if i should even bother having it painted or just have it touched up.. i really dont want the door to not match... anyone know what the best route would be to go? thanks
Benjamin Simon
08-09-06, 06:12 PM
You might need to ask the caddy dealership for help on this one. When you paint white dia, it is a 2 step process. Most shops have no idea how to do that.
6.0 Litre
08-09-06, 06:41 PM
Actually it is a 3 step process, base, pearl, and clear. Though this paint is hard to match it can be done, "depending" on the shop. I had two different items sprayed at different times (2004 White Lighting color) and they matched with no flaws, by the same shop. Being that it is factory paint I think the pressure of how the paint comes out has something to do with the shops compressors (output). I maybe wrong but I know pearl paint is one of the hardest to match.
I'd say take to a paint shop that has a history of doing candy paint and pearl paint jobs - those lowrider guys might be able to do it. They did mine. hope this helps in someway.
boatmanea
08-09-06, 08:51 PM
I am also very meticulous and detail oriented... I bought 2 touch-up bottles from the dealer - one of the white base and one of the pearlescent. It works pretty well. Unless it's in direct sunlight, you can't see small scratch and chip touchups. The only reason I notice them, is because I know where they are.
-E
05 Cadillac Escalade
08-09-06, 08:59 PM
As stated, it is a three step process that includes blending. The shop that does the painting will need to also blend the original paint around the fresh paint to make it look right. I had minor hurricane damage last year on my 2005 White Diamond and I had the dealership repaint a small section on my Escalade. They had to do it twice because the first time didn't match correctly. It eventually came out perfectly and I can't even tell the difference. See if your local dealership can do it.
Thanks.
I have seen some very good touch ups where doors or different panels were repainted, and I have also seen my share of poor painting too. It's a hard color to match correctly, but can be done.
amtrucker22
08-10-06, 06:43 AM
I know how you feel. I am very picky with my Caddy. I just had my front end painted after a wreck she was in. I asked a friend of mine who is a insurance adjuster, which shop was the best in town. Needless to say they did a great job and I was thoroughly impressed. If you have an independent insurance company you may want to ask them. Good luck!
Paul
NightHawk150
08-10-06, 11:14 AM
Pearl White is one of the hardest colors to paint. It is three stage color (base, pearl, and clearcoat) and if you mess up, even if it's just something small, you have to start all over again cause with this color, the word touch-up does not exsist. I'm thinking you're pretty much gonna have to repaint the whole door if you want it done properply, and even then, you're gonna have to be very careful just to make it match the rest of the truck.
08-10-06, 11:34 AM
:yeah: That is what happened when my dealership was repainting part of my driver door from hurricane damage. They messed up in one of the three stages and had to start over again. It was basically a waste of a day and more time away from my Escalade for me. It does look perfect now as I said before. You would never know it was repainted.
Thanks.
