: turn signal problem ('94 STS)
Reactor
08-08-06, 09:42 AM
Both left and right turn signals have stopped working, they seem to try to work every once in a while.
Emergency flashers works.
Manual states there are 2 flashers, I can only see one silver can flasher under the dash, (replaced it, no change). Is 1 flasher for the emergency lights, and the other for the turn signals?
Where is the other flasher located?
I supected the turn signal switch, changed it, ( what a job), but no change.
Please Help
Thanks
Reactor
08-09-06, 09:40 AM
Since I did not get any replies, I went to Ask.com.
I was sent in the direction of the left side of the steering column.
After removing the kick panel, the knee panel, and a metal plate covering the
steering column.
I did find the turn signal flasher relay hidden, mounted with a clip on the
back side of the left none removable knee panel, behind the lip edge of the panel, it is black and can not be seen if you do not know that it is there.
I replaced it and that corrected the problem.
FYI
CadillacSTS42005
08-09-06, 10:04 AM
prob didnt get any hits b/c this is technical discussion about the N* not about electrical, this should of been posted in the electrical section or at least the section of which car you own.
94CaddyConcours
08-14-06, 06:18 PM
I dont even bother at mind anymore. My left brake light doesnt lit and the buld are not burnt. Also ther left flasher flash faster than the right when the headling is on and right is faster when headlight is off. Oh well whose care.
urbanski
08-14-06, 06:27 PM
steering column.
FYI
glad you found your answer.
this was not the proper forum for your question, which is why nobody replied.
