View Full Version : Now Available Cold Fusion Nitrous Kits
UGOTIT
08-03-06, 10:03 PM
Stripper Motorsports is proud to introduce the Cold Fusion Nitrous Kits. We carry a variety of kits. If you are new to nitrous, then we have the dry kit for you. It is cheap and safe. Most dry kits are adjustable from 50 to 100HP. If the wet kit is the way you like to spray. Then get one while they are cheap. We have single nozzle wet kits, dual nozzle wet kits, and even dual stage kits. We also have a 90mm LS2 plate system that works greta on the TBSS. If you want to run with the big dogs then step up to the Direct Ports FOGGER. This kit is adjustable from 150 to 600HP. This kit is for the more experienced user. Also if you want to build a better motor with good forged parts and your girlfriend says your motor is fine. We carry the DUAL STAGE FOGGER if you want to blow that stock motor to pieces to prove her wrong. Trust me they are not always right and this is the kit to prove it.
Cold Fusion has a great kit and I would not be trying to sell it if I did not have one on my own vehicle. Call 1-866-708-7744 to see which kit is the right kit for you!!!
Thanks,
Brad
