wps
08-02-06, 05:25 PM
Purchase Date:3/21/06
Today’s Date:08-02-06
Mileage about 3000.
2006 Cadillac DTS downhill inadvertent acceleration problem. The car is new.
This is a great car but it has some real quirks that I am not sure we can live with them.
1. We live in hilly country. When going down hill the car will accelerate with your foot off the gas pedal about every 100 yards depending on the grade. This is especially bad on the turns. You do not expect a car to accelerate with your foot off the gas peddle on a turn or any other time. This is a safety issue. The acceleration problem also happens while trying to park the car. It takes excessive use of the brakes to keep the speed down and drive in a safe manor. When going down a grade we shift the car into a lower gear. The speed limit in town and the residential areas here is mostly 25 to 35 mph and in town the car should not even be in drive. The only time in town that it goes into drive is when you let off the gas peddle. This causes the car to coast excessively. We run the car mostly in 3rd gear around town.
2. The max tire pressure is 30 on the door post, 44 lbs. on the tires. During the hot weather the pressure has gone up and the computer continuously flashes and makes noises. I lowered the pressure and it seems better.
3. The windshield wipers will run with the window completely dry, be sure not to leave the wipers on auto!
4. We are hearing a weird noise. It sounds as if it is coming from some part of the front of the car, also at around 70 mph. There is no message being displayed. It is a buzzing sound and it comes and goes. I tried opening and closing the sun roof. This did not seem to make any difference. We will be contacting the dealer to see if they have any answers.
These problems take the fun out of driving this car!!
The dealer has had the car for testing two times for several days. This surging is happening in parking lot as we were trying to park. The technician was not able to reproduce this problem in the parking lot, but was able to reproduce the other surging problem. This a built in computer function to save gas as explained to us by the dealer’s head technician. The technician said that the company has no repair for this car at this time. Unless there is a computer update, there is nothing to be done. While going down a hill the computer shuts off the gas. When the engine reaches about 1000 rpms the gas is turned back on. At this time the engine runs up 600 to 700 rpms. The engine does this continuously as you go down the grade. If you are going down a grade you have to put on the brakes continuously to keep the speed down. This situation becomes dangerous while going around the windy down hill grades in hilly country like where we live. Right as we turn into our drive way this happens almost every time. It happens even with your foot on the brake.
The cure for this is as I understand it from the technician and one of the owners at the dealer is to always drive in overdrive and use the brake instead of shifting down. This was their recommendation.
We have contacted Cadillac and they tell us there is no fix for this problem.
We contacted NTSB on May 1, 2006. They have not contacted us.
The acceleration problem is a safety issue the others are irritating.
wps
Mileage about 3000.
wps
