View Full Version : Fog Light question?
GBcadi
07-29-06, 06:18 PM
When I have my fog lights turned on, they only come on when I signal. If I signal left the left fog light comes on and when I signal right the right side comes on. Also my high beams comes on by itself sometimes. Anyone else have this problem?:confused:
AwfulSmokey
07-29-06, 06:53 PM
you sure you arent confusing the fog light with the light that comes on to turn? Caddy's have a light that comes on when you turn so you can see on the side of you.
imtruly1ofakind
08-01-06, 08:43 PM
GBcadi--->Caddy's have a light that comes on when you turn so you can see on the side of you. i didnt know that. But I am having the same proble wit my fog lights. At first 1 of them stopped workin...now they both dont work...I tried checking the fuses but they're fine
bengsxr
08-02-06, 12:11 AM
ok yes caddy's and several other cars have what I call corner lights meaning they come on so you can see the side of you so you don't hit the curb or miss the turn. But the first thing you should do is check your bulbs then go from there. and for the high beams coming on all by them selfs is weird and a new one to me but I would maybe guess a wire around the headlight area might be shorting out. Ben
todd2fst4u
08-02-06, 09:58 PM
the high beams coming on by themselves is probably the daytime driving lamps. read the manual and it should tell you that the daytime driving lamps (which are the high beams at reduced brightness) come on automatically.
GBcadi
08-03-06, 06:27 AM
My fog lamps at the bottom of my cover are not working when I turn them on. They only come on when I signal when the fog lamp button is pushed on and I signal. When I signal left, the left fog lamp one comes on, and when I signal right, the right fog lamp comes on. My lights sometimes come on when I turn on the wiiper blades also.
todd2fst4u
08-03-06, 09:39 AM
here are a couple pages out of the manual.
http://todd.bluesubmarine.org/wiper.JPG
http://todd.bluesubmarine.org/fog.JPG
