View Full Version : 93 N* coolant temp sensor
07-28-06, 05:35 PM
I did a search for this but im not sure if it changed between the 93-94 ish motor and the 95 on. I read that it was on the rear head on the left side. I pulled the intake cover and looked but i didnt see anything that looks like what i bought.
Any help?
07-28-06, 07:15 PM
Throttle body side of engine, on the rear head. It will be sticking out the side.
07-28-06, 08:00 PM
yeah found the little thing, problem now is how to get the new one in there. I cant really remove the lines and egr pipe.
07-31-06, 11:59 PM
You may have to un-do some stuff, but that is the only way to avoid frustration. The EGR pipe is sort of stiff, but it will pull out of the housing ( it's about a 1/4 inch inside), and it may be a 10mm - 12mm bolt. I think you are also referring to the fuel lines? Get the plastic quick disconnect 'donuts' and the lines should pop out. Have someone show you, if you are not sure how they work - you will find it's easier than you think.
