olaf_sc
02-08-04, 08:36 PM
Hello Folks,
I hope it's okay with some deep technical question of a rather simple problem - I have no spark when cranking (trying to start).
The background is that I have a 94 Concours (i.e. NorthStar Engine) which had a shot engine (rod bearing). Then to get a low milage engine I bought a 99 Deville long block.
Now as a long block they are rather different but according to my checks the short block should be the same. Hence I thought it was an okay thing to do. However the blocks are only nearly the same. Everything fits just fine old heads and valetrain along with all the old stuff around it. The only diff is the crank sensors they are of HAL type on the 99 while the old 94 has inductor type crank sensors (or what ever you should call them).
I used my old sensors and put them in the same place as the new once where (it's the same place as on the old block). The diameter is slightly smaller on the old one but that can just be solved with a o-ring holding it in place.
I now put the engine back in the car along with everything else and it was time for startup. Nothing - no spark at all.
Checked error (diagnostic codes) nothing (except for memory rest due to removing the battery). Checked that the ignition module had power - it had. Check resistance over crank and cam sensors - 1.5k on the cam and nearly 0 on the crank once. Checked if they produced any signal by using a volt meter and cranking the engine. Sure there is some sort of signal when you crank the engine.
Still no spark :(. Now what to do?
Question is the crank positioning teethes totally different in a 99 versus a 94? If not it should work to use the old sensors since they have the same length as the old once hence sit on the same distance from the sensor wheel on the crank. The hole in the block is also in the same position except that it's a tad bigger in the 99 since the sensors has a bigger diameter.
If it's nothing strange with the cranks sensor wheel what can it then be that makes it fault so I don't get a spark?
Even if there as differences and the sensors wasn't really in the right position whoudn't I get a spark but a crapty one at the wrong time so to say?
Very thankful for any suggestion, answer or tip to my problem.
Cheers Olaf
Cheers Olaf
