View Full Version : HELP! fuse
tommer
07-22-06, 12:37 PM
Ok, got the led's put them in, nothings working. Where's the fuse for the door ,dome,trunk?
B Hoth
07-22-06, 01:33 PM
Remeber you want to put them in one at a time. That way if they don't come on you just flip them the other way. Then if not the fuse is the next place to try. Location for these fuses is under the rear seat on the passeneger side. Just pull up the bottom cushion, you can't miss it.
FlyFlip420
07-22-06, 01:33 PM
You need to pull out the back seat.....just push in and pull up....you will see the fuse boxes......look under the cover and you will see the diagram :)
FlyFlip420
07-22-06, 01:34 PM
:highfive: damn hoth ya beat me...
B Hoth
07-22-06, 01:35 PM
Were responding in stereo flip!:highfive:
tommer
07-22-06, 02:16 PM
yep it's the fuse another trip to Walmart. thanks guys
tommer
07-22-06, 10:46 PM
changed the fuse, put the back seat in, put the leds in 1 at a time they all work I like the color but it's not very bright ,the trunk is not bright at all. need 2.I will do under the dash if there brighter. 6 rum& cokes and a bottle of water later it's all done.
