EDBSO
07-15-06, 06:19 PM
From my 2001 Eldorado
The Fronts:
With a jack, safety stands, beer and the following you have everything.
http://i17.photobucket.com/albums/b53/edbso/1.jpg
In point form.
1. Block the wheels
2. Remove the hubcap with a flat screwdriver. Use black or masking tape on the blade to protect the hubcap. Slightly loosen the wheel lug nuts.
3. Jack up the wheel (use safety stands under frame) and finish removing all lugnuts, tire and rim.
4. Remove top caliper bolt (as view from back side)
http://i17.photobucket.com/albums/b53/edbso/top.jpg
http://i17.photobucket.com/albums/b53/edbso/F2.jpg
5. Remove bottom caliper bolt, as viewed from the back side.
ALWAYS SUPPORT THE CALIPER never let the brake hose support the brake caliper!!!
http://i17.photobucket.com/albums/b53/edbso/F4.jpg
6. Loosen the bleeder valve. Personal preferance I do not like to force brake fluid backwards through the lines, valves and pump! Just my 2cts! Note: Others say NEVE EVER force the brake fluid back through the system because you risk getting dirt and sludge behind the seals and into the inner workings of the ABS system. I always loosen the bleeder screw.
7. Use "C" Clamp to push the caliper piston into the bore.
8. Close the bleeder and top up brake fluid.
http://i17.photobucket.com/albums/b53/edbso/F5.jpg
9. Remove the old brake pads and replace with PREMIUM brake pads. Seat them properly in their anti-squeal stainless steel holders.
(Did I mention have a beer?) http://i17.photobucket.com/albums/b53/edbso/F6.jpg
10 Put caliper back on and bolt to the support brackets. This is a good time to use some brake cleaner and spray any brake fluid that may have gotten on the various parts. NEVER get grease oil or any dirt on the rotors or friction surface of the pads!!! I don't even like to touch them with my hands.
MAKE certain that the caliper bolts are CLEAN well lubricated with a very high temperature grease and make certain that the CALIPER MOVES FREELY.
11 Reinstalling the tire and rim. - Time to do some preventative maintenance.
To prevent the rim from freezing to the hub it is best to inspect both for signs of corrosion or pitting. Clean with a very light sanding (skip sanding if in excellent condition) and lubricate with a very thin coat of the high temperature grease. Essentially you apply the grease and then wipe most of it off.
Torque the lug nuts. (Check, usually to 100 foot pounds).
A source of shimmy, vibration and brake pedal pulsation can be caused by improper torqueing of the wheel lug nuts.
After you have the rim and tire back on the studs finger tighten all 5 of the lug nuts.
At this point the rim bore has slid over the hub and the rim is tight against the rotor.
Tighten each lug nut 4 or 5 times in a crisscross sequence each time increasing the torque force till you reach the specified torque (usually 100 foot pounds). Tip after 2 or 3 rounds of tightening you might want to slightly lower the car till the tire touches the ground enough to stop it from rotating while you torque. Do not put the full weight of the car on the rim till you have torqued to specification, just enough to stop the rotation.
12 Remove safety stands and let the car down. Install hub cap.
13 Press the brake pedal several times to move the pistons up to the rotors. Start the car and apply the brakes and only if they feel normal shift into "D" drive 10" and stop. Put in park and remove wheel chock.
After a couple of days of driving check the lug nuts again for proper torque.
The rears. This is how my 2001 Eldorado works, your mileage could vary???
You know the deal, point form and start by collecting your tools and beer together.
1. Remove hub cap. Use black or masking tape on the blade to protect the hubcap. Slightly loosen the wheel lug nuts.
2. Loosed wheel lug nuts a bit
3. Chock wheels
4. Jack up (use safety stands under frame) and remove rim and wheel
5. This is what you should see if the rears are the same.
http://i17.photobucket.com/albums/b53/edbso/2.jpg
6. Remove the 12mm calpier bolt from the rear, the caliper is now slightly free to rotate on its axis
http://i17.photobucket.com/albums/b53/edbso/3.jpg
7. The caliper won't rotate enough because of the emergency brake cable it must be unbolted
View from the top
http://i17.photobucket.com/albums/b53/edbso/4.jpg
8. Remove the bolt and the caliper is now free to rotate and the old pads can be removed.
http://i17.photobucket.com/albums/b53/edbso/6.jpg
9. Loosen the bleeder screw. You already know my preferance not to force brake fluid back through the system and Note: Others say NEVE EVER force the barke fluid back through the system because you risk getting dirt and sludge behind the seals and into the inner workings of the ABS system. I always loosen the bleeder screw.
10. Use the magic cube with a 3/8 drive and turn the piston into the bore.
11. Tighten the bleeder screw and add brake fluid
12. Install the pads and rotate the caliper down.
13. Rebolt the caliper
14. Rebolt the emergency brake cable. This is a good time to use some brake cleaner and spray any brake fluid that may have gotten on the various parts. NEVER get grease oil or any dirt on the rotors or friction surface of the pads!!! I don't even like to touch them with my hands.
15. Reinstall the wheel, rim and hubcap.
16. Remove safety stands and lower the car
17. Press the brake pedal several times to bring the pads to the rotors
18. Start, try brakes and if they feel normal put in drive and test from 2 mph
20. Season and brake in rotors as below.
See my post here on breaking in the pads. MOST IMPORTANT (http://www.cadillacforums.com/forums/cadillac-seville-cadillac-eldorado-forum/78724-bedding-performance-friction-pads-letting-smoke.html)
Most people after a great brake job using only the best parts do not finish the job off properly. They think they are through after torquing the last bolt down and kicking the wheel blocks out. NOPE! lots to do yet
Last Sundy I installed the Performance Friction pads on all corners. After testing in the driveway to make certain I still had brakes by doing 2 or 3 stops from 1 or 2 mphs I was ready to go around the block.
Accelerate to 25 mph and gently brake to 5 mph. Do not allow the vehicle to come to a complete stop.
Repeat the braking 25 mph to 5 mph 3 more times and then park in the driveway and let them cool for 4 or 7 hours. I usually leave them overnight.
Drive normally for 2 or 3 days with no hard stops and then bed the pads. I did that today Thursday.
Now bed the pads. Sorry no xxx here.
Choose a quiet highway or road of your choice. Accelerate 60 mph to 70 mph and brake hard to 5 mph. Very hard to 5 mph! Again do not allow the vehicle to come to a complete stop.
Repeat 5 to 7 times IMMEDIATELY! If your pedal gets soft or you feel the brakes going away, then you've done enough.
On the last stop the brakes should be very hot and even smoking! Your stopping distance could be 3X what the first stopping distance was. Sometimes the rotors and pads will get so hot even braking with full force will barely slow the car down. Do this on a quiet deserted road.
You are in full brake fade. AND may not be able to stop the car. This is good. Your brake rotors and pads are now full bedded. Some call it letting the smoke out. Yes they will smoke and stink.
Drive for 20 or 30 minutes to cool your brakes and you are done. Your brakes are now proper bedded and again I usually let them rest the night.
Your brakes will have improve pedal feel, reduce or eliminate brake squeal, and bedding will extend the life of your pads and rotors. AND they will work very very well.
If you have cheap crappy rotors you probably warped them. If you have cheap crappy pads then they faded after 1 or 2 stops. Better to discover this sooner than later.
So do you want to know about cryo treating your pads and rotors? Nope you arn't ready cryo treating info (http://www.cryogenicsociety.org/cryo_central/cryogenic_treatment_of_materials.php)
The Fronts:
In point form.
1. Block the wheels
3. Chock wheels
View from the top
