View Full Version : wiring oil pressure sensor
unruley247
07-14-06, 07:07 AM
My oil press sensor is crazy been replace and test but will still me low ps n stop engine when it gets ready. I can start it up and i get the warning or b doing 100 mph and get the warning and that not a good feeling when you are goin that fast and you c that warning com up but anyway the pressure is fine just want to elim problem thanks
Ranger
07-14-06, 10:17 AM
Did you use an A/C Delco oil pressure switch?
unruley247
07-14-06, 04:59 PM
Ac delco only on my cad the only way 2 paid money:)
Ranger
07-14-06, 08:59 PM
I was going to suggest the check valve may be stuck, but since it is intermittent, I doubt that. I can only think of a bad switch but that has been changed so I am at a loss.
unruley247
07-15-06, 06:10 AM
maybe i will have to run a offline oilpress guage for my own protection car runs great its just throws me of when i see stop engine low oil press.
Ranger
07-15-06, 10:05 AM
You could put a mechanical guage on it to verfiy the actual pressure. Then you'll know if it is a guage problem or not.
unruley247
07-15-06, 02:30 PM
My mech ran a oil press guage to check the press and verify it was a bad switch. That when we replaced the guage with a new one.
Ranger
07-15-06, 08:51 PM
Hmm, maybe a bad one? I'd probably be inclined to R & R it again.
unruley247
07-15-06, 09:51 PM
Mayb i might just do that but the one i took off was doin the same thing
Ranger
07-16-06, 03:47 PM
Maybe a wiring problem then.
