pimpcaddy
07-13-06, 10:23 AM
I use keyfob #1 and it always defaults to driver #2 when the V starts up. I looked through the personalization menu and didn't see some sort of default setting. Any help would be appreciated.
Dave
Dave
| View Full Version : Question about Personalization... pimpcaddy 07-13-06, 10:23 AM I use keyfob #1 and it always defaults to driver #2 when the V starts up. I looked through the personalization menu and didn't see some sort of default setting. Any help would be appreciated. Dave nikon 07-13-06, 10:41 AM use keyfob #2???? mine are switched #1 does 2, #2 does 1...so I use keyfob #2. Holmes815 07-13-06, 11:32 AM If you really want to keep yourself number 1 (the case that is) you could switch the guts from one to two. NH Vrod 07-13-06, 11:50 AM Don't you have to pop off the back of the case to change the battery? just change the backs. ewill3rd 07-13-06, 12:11 PM Sounds like whoever programmed them did it backwards. The number corresponds to how they were programmed, not necessarily the number on the back. I agree, swap the guts would be the easiest. Swapping the back will work but you have to remove the key ring first. v-ape 07-13-06, 02:59 PM Don't you have to pop off the back of the case to change the battery? just change the backs. hahah, the easy solution (although your FCC ID wont be correct as imprinted on the back, but who cares). That reminds me of the NASA research program to develop a pen that would be able to write in the absense of gravity, I believe they spent $1M. A few years later, they talked to the russian astronauts and asked them how they did it and they said "We just use pencil". pimpcaddy 07-17-06, 11:37 PM You guys were right about switching the fob. Done. Thanks, Dave P.S. doesn't that mean "fresh off the boat"???? | |
