View Full Version : Just a thought...maybee a easy fix for the peeling radio buttons??? Well, I was thinking about it today and a rather simple idea popped into my head......what about clearcoat??? I mean, maybee not actual clearcoat, but something along the lines of it....even a dab of superglue spread evenly on the buttons would work, and if smooth enough would even give a little shine...theres gotta be a better product then superglue or clearcoat but, I think im on the right track...and the volume and multi knob thingy you could just take off and dip it into the magic clear stuff whatever it may be...whatcha think? Opinions? is it too easy? did I miss somthing?
edit: found this stuff on a quick google http://www.starbrite.com/productdetail.cfm?ID=1081&ProductCat=Home%20Care&ProductSCat=Liquid%20Electric%20Tape%20%28Home%29&ProductSSCat= beaglecookie 07-12-06, 10:09 PM I was thinking clear nail polish. cheap and lasts a long time. Easy to reapply too. It not real thick and lumpy so you won't be apply to notice you added something to your nav or radio knobs. Just a thought......:bigroll: thefred 07-12-06, 10:37 PM I don't know about that. It seems that the problem is that the paint is not well bonded to the button-alas the chipping. I fear that adding anything on top of the paint could worsen the problem by adding weight to an already "loose" paint. Just my .02 JAY WEST 07-12-06, 11:38 PM Clear high quality sticker with custom cut (doesn't have to cover whole contour either) over buttons? Even with a red or blue tint if that is your style. Mine is an 05 and no flaking yet at 38k mi., I'm sure they will now start tomarrow now though. Jay. clear nail polish sounds good, Il prolly try that, and its funny before I opened the thread I was thinking the same thing about a sticker like the same material they use on the invisi bras, just not as thick....and I understand the paint isn't bonded well, but I think it's when you puch the button your finger slips....I think thats why some are having problems and some arent, its the way you push the button...and Im one of those that my finger slips a little when I push it...I think Im gonna try the nail polish....good idea, k thanks. beaglecookie 07-13-06, 08:58 AM I'm going to put the clear nail polish on my radio buttons too. If it doesn't come off my nails and I'm on a computer all day then it should last on my radio buttons. Just put a double coat....:thumbsup: I'm going to put the clear nail polish on my radio buttons too. If it doesn't come off my nails and I'm on a computer all day then it should last on my radio buttons. Just put a double coat....:thumbsup:
just make sure it doesnt run into the cracks..like interfear with the button being pushed....2-3 light coats might do it...Ill have to get some of that from my gf...good luck. beaglecookie 07-13-06, 09:22 AM Your best bet is to get it from your GF. All you need is for her to find it in your car.:eek: She'll be wondering who the hell you had in your car???:thepan: Your best bet is to get it from your GF. All you need is for her to find it in your car.:eek: She'll be wondering who the hell you had in your car???:thepan:
:histeric: I've been thinking along the same lines. Even considered doing a little masking and then some light spraying with something like 3M Scotchkote or some other brand clear coating. Nail polish was a consideration too :) 50 4Ever 07-13-06, 02:58 PM How about some 3M Clear Bra material. The guy that installed my Clear bra on the Corvette has all kinds of scraps laying around.
Just a thought :thumbsup: Imperator 07-13-06, 08:17 PM Yea, I'm thinking about the clear plastic adhesive "protectors" that are now sold for PDAs and cell phones. I just need precise measurements of the buttons to have a die cut. Midlife Z06 07-13-06, 10:50 PM Here is how I fixed my peeling problem. The buttons had a few chips in the paint and so did the volume knob. A bigger problem was the paint peeling off the plastic surround panels near the buttons. The shiny black plastic below the charcoal color paint really looked ugly. Worse than the white plastic below the peeling paint on the buttons. The paint on the right edge of the radio had also peeled
First I gently rubbed the peeling paint area with a cloth to be sure the area was flat and all flaking paint was gone.
Next I took a can of hi temp charcoal color paint for a barbeque grille. A flat black color that matched the buttons and plastic perfectly.
After shaking the can thoroughly, I sprayed the paint into the cap from the can. Just a little.
I next dipped a cotton swab in the paint in the cap. Again just a little.
I then pressed the end of the swab against the peeled areas, just dabbing not stroking. You want to get the least amount of paint to keep the touch-up flat with no build up or edges. Keep dabbing until you cover the area.
If you use the smallest amount of paint it will dry quickly and match the paint color pretty darn good. The buttons can be touched up this way too but the buttons seem to have more shine to the color. After the paint dried
I ruubbed a finger on the buttons. The small amount of oil on my skin made the button shine to match the others.
I liked the results. Try a small area first that is the least visible.
Good luck. lasstss 07-13-06, 10:51 PM Perhaps one of you guys can research this..
Polyurethane Coatings for Automotive Interiors
A growing number of automotive manufacturers are using special-effect polyurethane coatings containing Bayer resins to add a soft, luxurious feel to plastic interior components such as steering wheels, airbag covers, instrument panels, door handles and many other interior trim plastic parts.
Special-effect coatings provide durability and an attractive surface for these high-use hard plastic items. They also provide chemical resistance, scratch and mar resistance, and UV protection. In addition, they eliminate "fogging" associated with PVC plasticizers and frequently yield a cost savings when replacing vinyl wrapping.
Special-effect coatings are two-component (2K) coatings based on the reaction of flexible polyester polyols with mixtures of aliphatic polyisocyanates.
Bayer also offers environmentally friendly products and technologies. In fact, Bayer received the Green Chemistry award from the U.S. Environmental Protection Agency for developing an industrial coating material that uses water instead of chemical solvents, thus reducing volatile air emissions by as much as 99 percent.
Special-effect coatings can be tailored to protect and enhance the many different types of plastics commonly used for interior automotive components. They offer:
Excellent adhesion to most plastics
Flexibility needed to match various types of plastics
Low-temperature curability essential for many heat-sensitive plastics
Easy repairs with scuff sanding of defects and then full coat application
Easy application using conventional or electrostatic spray equipment
Wide range of colors and gloss options
Recommended products include those sold under the Desmodur (http://www.bayermaterialsciencenafta.com/products/index.cfm?mode=grades&pp_num=EB7C52DD-F4EC-BDA1-6BE0225FEE5C1FD0&o_num=14), Bayhydur (http://www.bayermaterialsciencenafta.com/products/index.cfm?mode=grades&pp_num=EB7C4D50-D07F-AA6C-60B88352A8DDF920&o_num=14), Desmophen (http://www.bayermaterialsciencenafta.com/products/index.cfm?mode=grades&pp_num=EB7C580E-AD62-3006-3A874469CEBF2CF2&o_num=5) and Bayhydrol (http://www.bayermaterialsciencenafta.com/products/index.cfm?mode=grades&pp_num=EB7C4BD9-0DCD-BBE0-A4B3F13F669BA736&o_num=13) tradenames.
For additional information about special-effect polyurethane coatings for interior automotive parts, ask your coatings supplier. For information about coating raw materials, contact us (http://www.bayermaterialsciencenafta.com/contact/).
Polyurethane Coatings for Automotive Plastic Components
More than two billion pounds of plastic are used annually in the North American Automotive Industry for exterior and interior parts ranging from body panels and fascias to instrument panels and steering wheels. Polyurethane coating systems using Bayer raw materials and colorants help provide a durable, long-lasting and high-quality surface finish for these components.
Two-component (2K) solventborne, and waterborne systems are the most common polyurethane coating formulations, and they deliver key properties such as:
Environmental etch and chemical resistance
Class A surface finish
Low-temperature cure
Good adhesion properties
Variable flexibility
Mild solvent use
Low VOC capability |
