: What does "B2118 - Front Vertical Sensor Failed" mean?
sprj
07-11-06, 08:44 PM
What does this mean and what may be necessary to correct it?
JimD
07-12-06, 06:51 PM
It means the seat position memory system has detected a fault.
What year/model car are we talking about?
eldorado1
07-12-06, 07:34 PM
seat position? Isn't it a ride height sensor?
sprj
07-13-06, 11:28 PM
97 Seville SLS
JimD
07-14-06, 06:21 AM
The Service Manual I have is for '98 and I have no idea how different or similar the seat controls might be.
The front height position sensor is a 10K Ohm potentiometer. B2118 is tellling you the voltage is out of range which could be a failed/damaged potentiometer, damaged wiring, or damaged connector.
The manual seat tilt should operate normally; the height position sensor is only used for exit, memory recall, and memory set operations.
sprj
07-14-06, 08:20 AM
Thanks for the info.
