View Full Version : Is this all it takes to break into the Escalade?
TheCaddyKidd
06-30-06, 02:34 AM
found this pic on ebay on an ext that was broken into...I didnt see any windows knocked out or anything.. just this..
hcvone
06-30-06, 06:46 AM
That is one way. Many many years ago I owned a chain of hardware stores, and went to school to get my cert for being a locksmith to teach my employees, I have tools to get into cars and houses in seconds, I am sure in these days of the internet just about anyone can get these tools. :(
jrs05caddyext
06-30-06, 08:57 AM
I had the key hole punched in.
fast66
06-30-06, 11:31 AM
THAT IS EXACTLY HOW THE STOLE MY OLD RIMS
Synergetic
06-30-06, 01:10 PM
Simple as that... i'm glad they broke my window than doing that.
GIO
06-30-06, 01:59 PM
Im getting billet covers with no key hole
The only way there taking it is braking the window or tow it, then my clifford will let me know.
Then:gun:
jrs05caddyext
06-30-06, 02:03 PM
or the jimmy jammer
http://www.lildevilmotorsports.com/cadillac-escalade-jimmi-jammer-indoor-lock-protection-front-doors-p-4295.html?manufacturers_id=112
Kappa-Lac
06-30-06, 03:20 PM
or the jimmy jammer
Jimmy Jammer will stop the theft but will not stop the damage. It costs around $900 to get fixed.
BG 03 ESV
06-30-06, 03:57 PM
Then:gun:
I like the idea but I don't like the chrome covers. Are you going to need the rear door linkage?
Wonder how much would a body shop charge for parts and installation?
jrs05caddyext
06-30-06, 04:01 PM
I would rather have that damage to my door than have the vehicle stolen. It also helps to have connections at auto/body shops so they can fix it for less
GIO
06-30-06, 05:12 PM
It's getting done will show pics.
vietfob714
07-02-06, 08:44 PM
does the jimmy jammer really work?
fast66
07-02-06, 08:55 PM
They drill the hole there so that they can pull the metal wire that unlocks the door,
Just remove the metal wire so they cannot pull anything.
Jimmyjammer does the same.
wth metal wire gone, door keyhole will not work.
This has been done on mine
TheCaddyKidd
07-02-06, 09:18 PM
the only down fall to getting the jimmy jammer or blocking out the keyhole is that if you battery goes dead and your keyhole doesnt work how do you get in the truck? on my truck i just put the hood latch security covre on so that you cant just pop my hood open with a screwdriver... so if the battery goes dead and you have no keyhole there is no getting in the truck? i guess youll be smashing in a window lol
fast66
07-02-06, 09:32 PM
I have 3 yellow tops in my truck and a 280a alternator.
3 batteries will not die, trust me
also passenger side keyhole works
TheCaddyKidd
07-02-06, 10:01 PM
I wasnt exactly referring to your specific vehicle but in general most people dont have 3 batteries and such... I was just saying in general if someone to go that route how do you get in if battery is dead..
DeePDiSHeD
07-02-06, 10:20 PM
you could always run a positive cable somewhere accessible under the car to charge the battery if it dies.
TheCaddyKidd
07-02-06, 10:22 PM
thats not a bad idea.. i have been actually thinking of doing lambo doors with shaved handles so that would clear up some worries of the shaved handles if i got that route..
fast66
07-02-06, 10:50 PM
the problem with that is from the outside, how will you push the door up?
i dont know for sure, but i think you have to push the lambo door up, it doesnt go up on its own.
I like the idea though. very smooth
TheCaddyKidd
07-02-06, 11:20 PM
well from the videos i have seen the lambo kits are pulled out away from teh car and most people in the videos use like 2 fingers and squeeze the edge of the door and pull/push it up with just two fingers... so it would basically be the door poppers popping out the doors and then just pulling the door open at the edge and swinging it up as i mentioned above... some people have said that the lambo doors are heavy however i read that the springs are rated to hold doors that weigh in excess of 300 pounds and i dont think the doors are that heavy unless im missing something... there are kits out there however that i have seen that do make the doors go up automatically... they take a little while to go up but its all powered.. my only concern would be if i was in a hurry.. not sure if you can lift and such manually...
USAF_C17
07-03-06, 02:43 PM
Anyone know where the best deal on a jimmy jammer is? Thanks
David Sorg
07-03-06, 04:20 PM
If you keep your factory trailer hitch, you can trickl-charge the battery through it. Probably wouldn't take long to get enough of a charge to pop the electric lock...
fast66
07-03-06, 09:53 PM
never thought about that.
customizer
07-05-06, 08:01 PM
Doesnt leaving the passenger side door lock working defeat the purpose of taking off the drivers side? What they do on the drivers side can just as easily be done on the passenger. All they are doing is manually unlocking the lock from the backside of the lock cylinder. Only thing I can guess is that you are relying on them going fr the drivers side instead of the passenger side.
DBrisson
07-05-06, 09:13 PM
When I locked the keys in my esky it was easier to use a coat hanger on the rear doors. I was in the car in about 3 mins of shifting the hanger around the door release mechanism.
If the positive line of the batteries is suddenly shunted to ground I think only a alarm with an internal battery is effective. This is how thiefs got into a friends mustang, they even left the half jumper cable they used to short the batteries to the frame. It was a mess to repair.
Guyz1996deville
07-07-06, 12:17 PM
There are so many technological advancements that make it look like the thief is more detured. For example the satalite alarm systems are great. You can be any where until you find out you car/truck is being stolen, for a split second. All the theif has to do is pull the car in a aluminum trailer and the sygnal is lost. Or you can just wrap aluminum foil around the pickup sensor. The best defence is a good offence. Put the siren in the cab, and under the rear bumper, and under the hood. At this rate the person will have ear piercing decibels while he is working inside and out...
GIO
07-07-06, 04:08 PM
A small price to pay when it happens.
