: Replacing front crank oil seal on LT1
425 Dual Quad
06-23-06, 01:39 PM
Hello chaps.
Sorted the oil change on the '94 Fleetwood yesterday. Got oil coming out the front crank seal on the LT1 motor. How do I replace the seal. Looks like getting the harmonic balancer off will be no fun.
Is there a tech tip/ any ideas?
Thanks
Nick
BCs71
06-27-06, 02:21 PM
I'd replace the seal for the water pump drive as well while you are at it:
http://www.impalaclub.com/naisso/forum2005/topic.asp?TOPIC_ID=30984
In fact, it may be leaking from there or the opti drive as well and dripping down the front of the timing cover, giving you the impression the bottom seal (crank) is the leaker.
These links below are for a Camaro, but the procedure is basically the same for balancer & hub removal. The hub is tricky, I've done it a bunch of times and it never seems to go completely smooth. You need a puller tool along with varying lengths of bolts that the puller will "push" against after the crank snout bolt is removed. The bolts need to be slightly smaller in diameter than the crank bolt so that they do not thread in, yet still thick enough so they are tough and do not bend when the puller "pushes" against them.
http://shbox.com/ci/cam_removal.html
http://shbox.com/ci/cam_install.html
Feel free to PM or email me if you have questions that are specific, I only check in here once a day, but not on the weekends.
425 Dual Quad
09-11-06, 10:43 AM
Thanks BCS71,
Replaced the seal. It all went well and no leaks so far. I think it was the crank seal and not the other one.
Many thanks for all your assistance.
regards
Nick Strattta
BCs71
09-11-06, 03:00 PM
Great to hear! I hope the crank hub removal and reinstallation went smoothly. That part always give me fits even though I know exactly what I am doing.
Cheers,
-BC
