View Full Version : Mystery Belt (Simple Question)
codewize
06-21-06, 02:19 PM
So I was wondering what that small belt is on the left side of the engine. I can't really see where it goes. It's half convered and half exposed. What the heck is that for?
caddydaddy
06-21-06, 03:00 PM
The waterpump. It's driven off of one of the cams. Make sure to check the belt for any wear, cracks etc.
codewize
06-21-06, 03:05 PM
Really? I would have never guessed. I guess the water pump isn't on the front of these puppies huh?
caddydaddy
06-21-06, 04:22 PM
I forget the reason it's over there, but it sure does make it really easy to change when it needs to be done!
zonie77
06-21-06, 04:51 PM
The engine is rotated 90 degrees grom RWD. That would be the front in a RWD car.
submariner409
06-21-06, 05:04 PM
Zonie77......In the N* the water pump is attached to what would, in a RWD vehicle, be considered the rear of the left cylinder head, driven off the end of one camshaft via a 1 2/2 to 1 stepup pulley/belt/tensioner arrangement. Just outboard of this is the transmission dipstick..... All the other belt-driven goodies are on the passenger ("front") side of the engine. You rotated the engine 90 deg. the wrong way.
zonie77
06-21-06, 06:49 PM
You're right.
ewill3rd
06-22-06, 01:32 PM
That whole housing on the back of the engine comes off, it connects the two cylinder heads to eachother and it also houses the EGR system.
It is an uncommon place in the realm of automobiles to put a water pump, but that is sure where it is.
