View Full Version : Overheating 95 Seville Sls
BIGMAN-7
06-18-06, 09:04 PM
New Radiator, Thermostat, Coolant At 50/50 Mix, Fans Are Operating Properly But My Vehicle Overheats. When Info Button Is Pushed No Info Displayed. Obd Works Fine But Information Won't Display When Button Is Pushed. The Car Is Overheating And The Displays Says ...a/c Compressor Off... Idle Engine.... Engine Overheat...... It Has 135k
Ranger
06-18-06, 09:18 PM
Check the water pump belt tensioner and make sure the purge line is clear and flows coolant. If all is ok, do a cylinder pressure test.
BIGMAN-7
06-19-06, 03:18 PM
WATER PUMP BELT TENSIONER OK, PURGE LINE CLEAR, NO LEAKAGE IN COMPRESSION TEST.....??????????:want: :want: :want:
Ranger
06-19-06, 05:42 PM
Hmm, not using any coolant? No bubbles in the surge tank when started cold with the cap off? Perhaps a faulty tempurature sensor.
BIGMAN-7
06-19-06, 08:06 PM
Thanks for the input......... drained and replaced coolant with dex cool....... problem solved!!!!
zonie77
06-19-06, 08:08 PM
Does it lose coolant?
Ranger suggested a cylinder pressure test, not a compression test.
Have a combustion byproduct test done. Radiator shops usually do them inexpensively.
There's a large chance the headgaskets are leaking.
BIGMAN-7
06-20-06, 04:28 PM
Mistake on test noted but so far the vehicle hasn't run hot since replacing coolant with dex cool...... it would normall run hot after 30 mins of normal driving...... no problems with my daughter driving it all day. I will have the cylinder test done for reassurance..... thanks.
zonie77
06-20-06, 07:03 PM
You should have the combustion byproduct test done after the coolant is in there awhile. Like I said, radiator shops do them much cheaper than mechanics.
BIGMAN-7
06-22-06, 09:40 PM
If headgaskets are leaking....... what then?
BIGMAN-7
06-22-06, 10:24 PM
another question..... what can be the cause of no information displayed when the info button is pushed? "change engine oil" can not be reset and nothing can be monitored...( coolant temp.... voltage) car flashes "system" and "change engine oil" while driving...... computer maybe? if so, where is it's location if it nedds to be replaced.... my daughter loves the car.....
Ranger
06-22-06, 10:25 PM
Fix it,
sell it "as is",
junk it
Only choices I can think of.
Jonny5
07-12-06, 04:35 PM
to fix, a faulty head gasket will cost about 2 grand or more. Then a new computer is another grand or so....... Get a new car
