View Full Version : Lights Needed Cerillo 06-14-06, 11:43 AM As you guys know im selling my 2003 CTS.
I need to replace the headlights on it since they are scratched up...
Im checking ebay but thought i would check here first since Ive gotten so many good deals from you guys in the past.
I need the entire headlight unit, right and left for 03 CTS
anyone have a pair to sell?
Thanks in advance,
Im trying to get it ready ASAP RobertCTS 06-14-06, 12:00 PM As you guys know im selling my 2003 CTS.
Thanks in advance,
HIDs or Standard? Cerillo 06-14-06, 12:10 PM HIDs or Standard?
I believe they are standard. Which ever ones came with the car factory. RobertCTS 06-14-06, 12:14 PM I believe they are standard. Which ever ones came with the car factory.
Good as the HIDs are very expensive. A few members converted to HIDs. Maybe they'll see this thread. They probably have their old lights. SoCadillac 06-14-06, 12:15 PM I don't know how badly your CTS headlights are scratched or pitted, but you also have the alternative of polishing them out. Here is but one solution:
http://www.sisweb.com/micromesh/acrylic_plastic_kits.htm Cerillo 06-14-06, 12:19 PM I don't know how badly your CTS headlights are scratched or pitted, but you also have the alternative of polishing them out. Here is but one solution:
they are pitted pretty bad from the first owner taking it through cheap car washes.
Due to that and the small size of the surface it will probably easier to replace them....
hopefully those folks Robert mentioned with the HID lights can sell me their old ones RobertCTS 06-14-06, 12:24 PM they are pitted pretty bad from the first owner taking it through cheap car washes.
I see you have an '03 and that peeling, pitting problem happens to the "03s. You may wanna see if you can sand them out with 1000 grit wet/dry sand paper and finish with polishing compound. It's sure a lot easier and cheaper. Cerillo 06-14-06, 12:27 PM I see you have an '03 and that peeling, pitting problem happens to the "03s. You may wanna see if you can sand them out with 1000 grit wet/dry sand paper and finish with polishing compound. It's sure a lot easier and cheaper.
well it doesnt hurt to try , I have to take it to get detailed at the body shop anyways. Cerillo 06-14-06, 06:35 PM nobody has extra lights for sale? they are on ebay all the time Cerillo 06-15-06, 11:18 AM yeah I know, I just wanted to check here first, since I trust this site and the folks on it. I find it kinda weird that the actual headlight housing is different whether you have HID's or not. I would think the housing is the same. Cerillo 06-20-06, 12:37 PM Bueler? Bueler? Bueler? FaithInWarbird 07-24-06, 05:54 PM does anyone have the part # for the replacement headlights of both if needed? beaglecookie 07-24-06, 06:35 PM Cerillo, Do you have warrenty left on this car. They're covered under the warrenty. I'm getting mine in a couple of weeks. Cerillo, Do you have warrenty left on this car. They're covered under the warrenty. I'm getting mine in a couple of weeks.
Is this really covered under the warranty? I didn't think cosmetic damage such as peeling on the headlights was completely covered. Figured it was just normal wear and tear. Well that's certainly good to hear! I just made a down payment on a 03 and I had already made plans to wet-sand the right headlight...also, are both of your headlights gritty...or just one? RobertCTS 09-12-06, 05:43 AM Yes the warranty will cover it. Several members have had them repaired. You don't need new ones. wait4me6920 09-12-06, 10:19 AM Are they pitted/scratched, or is it the coating coming off? Haven't some folks been successful in getting the dealer to replace or resurface the headlight modules? Are they pitted/scratched, or is it the coating coming off? Haven't some folks been successful in getting the dealer to replace or resurface the headlight modules?
Both. On the right side, theres like 2 scratches that are about 4 mm thick. And there is definite peeling action towards the top...like the coating is comming off. but the right side looks 100% brand new...not the slightest haze or scratch...:suspect:
Also, The dealer told me by buying the car, he would see if he could work out a cheap deal with cadillac to get the right headlight replaced...as in....I would still have to pay him extra on top of the price of the car....but apparently it would be a good discount...:suspect: I'm glad I came here! Now i know to tell that guy to take his extra headlight charge and shove it up....uhhh..up places I have an early 04, both lights peeling on the top of the lens. Warranty covered the repair to the lens. They had a guy repair the existing lens, it came out great. 2000 grit wet sand paper should smooth it out if your out of luck on the warranty. After the wet sand use a gentle touch with the polishing compound to gloss it and then heavy on the wax. Synthetic like Zano or the New Nanowax should work great for the sale. I have an early 04, both lights peeling on the top of the lens. Warranty covered the repair to the lens. They had a guy repair the existing lens, it came out great. 2000 grit wet sand paper should smooth it out if your out of luck on the warranty. After the wet sand use a gentle touch with the polishing compound to gloss it and then heavy on the wax. Synthetic like Zano or the New Nanowax should work great for the sale.
yea its got 39,000 miles so its still under warranty :bouncy: Sooo...I guess i jus show up...and be like..."yo need a new headlight...this 1's got scratches" ha ha...probably not...Well, 1st think I should smack that dealer 4 tryna get me to pay extra for him "hooking me up with a deal" on my headlights..:want: then I will go to cadillac and see what they say :thumbsup: Sounds like your on the right path now! Pitting is one thing, but they are never suppossed to peel. |
