View Full Version : How to keep the rubber hood seals on?
r_casino
06-13-06, 01:56 PM
I need to refit the rubber hood seals back into position OFTEN. It's either the sides falling off or even the rear (near the windshield) falling off occasionally.
Anyone know if I can use some sort of "glue" to keep those fastened? Is there a reason not to glue 'em?
calicadi
06-13-06, 09:14 PM
I had that problem on my V-6 CTS. Cured it with non-hardening Permatex gasket compound.
calicadi
06-13-06, 09:17 PM
I had that problem on my V-6 CTS. Cured it with non-hardening Permatex gasket compound. Just a couple of dabs where it did want to grab tight to the metal edge. I suppose there's a special adhesive but the Permatex worked fine and I had it lying around, so what the heck.
blown black caddy
06-14-06, 01:40 PM
Have you tried fast-tack trim adhesive made by 3M?
r_casino
06-15-06, 10:59 AM
Thanks for the info....I'll take a look at both suggestions and try one out next chance I get.
The rubber trim falling off is really only a slight hassle as far as putting it back in place, but I'm a bit concerned about what goes on under the hood as I'm driving and that stuff is flapping around. (Especially the short passenger side trim piece.)
