sylvain Francoeur
06-10-06, 11:02 AM
Greeting all
Have SLS 94 with a 4.9. When got home, notice engine was running rough. Check all wires etc, all was fine. Change, plugs, wires, distrubutor cap, rotor, pcv,air cleaner. No changes. used a can of fuel injector cleaner, nothing positive, problems remain the same. When I changed spark plug, noticed #5 cylinder's plug being dark ( carbon) not oil. When to the dealer with it, all checked okay. Cleaned throttle body with cleaner, found both tubes full of deposit, cleaned that. No change. Gave it a good ride ( high speed) no change. Check vacum steady in the green. Decided to pull spark plug on cyl #5 same black deposit. While engine was running pulled spark plug wire from the spark plug, noticed no changes in engine, same constant rough running. It reminded me of cars in the 70 when you had a valve burn etc. Well it does the same...About to pull heads off and get them redone. Any advise prior I do this. ( also done, the toilet paper check at the tail pipe, I can hear a missing piston, )
I love this car!! ( sorry it is a 93)
