madooch
06-08-06, 07:47 PM
can someone tell me what the correct tire pressure for 235/60/16 would be for the sts the door label says 32psi but i feel its better at 40psi and how much air can i put in that wont be to much.
| View Full Version : tire pressure madooch 06-08-06, 07:47 PM can someone tell me what the correct tire pressure for 235/60/16 would be for the sts the door label says 32psi but i feel its better at 40psi and how much air can i put in that wont be to much. fpmesiIII 06-08-06, 08:13 PM i have 225/60/16 and i run 38 in the front and 36 in the back, cold tires. Ranger 06-08-06, 08:25 PM 32 psi is what Cadillac recommends. Lower will give you a better ride. Higher will give you better milage. Max is listed on the sidewall. I would suspect at 40, you'll see wear in the center of the tread and a shorter tire life. | |
