: Mirror Wiring Harness - Inviscord
d0n
06-07-06, 09:22 PM
Does anyone know which cables in the rear view mirror harness are power and ground? What colors? I'm trying to put in an invisicord for my V1.
Thanks
StealthV
06-07-06, 09:29 PM
The FAQ knows all (well mostly). :)
http://www.cadillacfaq.com/faq/answers/v1install.html
51PHFTY
06-07-06, 09:30 PM
Thanks
CTS-CTS-V FAQ: Valentine 1 Radar Detector installation (http://www.cadillacfaq.com/faq/answers/v1install.html)
StealthV
06-07-06, 09:31 PM
Your link is much more pretty. :thumbsup:
51PHFTY
06-07-06, 09:32 PM
Yeah, but you are faster.
d0n
06-07-06, 09:37 PM
Thanks guys but I was looking to simply plug the wires into the mirror wiring harness. http://invisicord.com/index.html It's similar to the faq install I was hoping to simply pop the wires inviscord into the harness.
StealthV
06-07-06, 09:50 PM
Looks to me like you should be able to pop the Inviscord wires into the ones described as power and ground in the FAQ link, right? Or am I missing something? :hmm:
StealthV
06-07-06, 09:54 PM
Black = ground
Blue wire with WHITE stripe (adjacent to the black wire in the connector - if we call the black wire position 2 in that row (there are 4 wires) then the blue/white stripe wire is position 3) = +12V delay switched.
http://www.cadillacfaq.com/faq/answers/img/v1-3.jpg
d0n
06-07-06, 10:03 PM
It looks like the harness in the faq (if I read it right) is the harness from the sunroof. I have the instructions and it's a different color wire for each car. The closest thing they have listed is the C5 - orange and Brown, c6 - Pink and black, STS - Pink and black, Escalade - yellow and black. I'll break out the ole volt meter this weekend and figure out which wire is which. Thanks.
StealthV
06-07-06, 10:11 PM
So why not just use the sunroof wiring harness?
CIWS
06-07-06, 11:30 PM
I "lucked out" when the dealership replaced my front windshield, the tech decided to clean up the wiring harness and tucked away the excess very nicely. I made sure to tell them it was noticed and appreciated.
d0n
06-10-06, 01:12 PM
Installed the invisicord today. The two wires you need to plug into on the harness are the pink (power) and bare silver wire (ground).
Simply unplug the harness from your rear-view mirror, remove the small cosmetic cover from the back of the harness. Plug the invisord in yellow-pink, black-bare silver. Replug the harness and you are done. The whole process should take less than 5 minutes. No splicing no cutting.
51PHFTY
06-10-06, 02:49 PM
Thanks for the link and the tip.
Marty
