: 2000-2004 crank sensors
dgarrett
06-04-06, 02:21 PM
Aar the 2000 to 2004 N* crank sensors reluctant type or Hall effect?
Thanks!
fhutchin
06-05-06, 09:45 PM
And while we're at it: I just pulled codes on my engine and they indicated a failure in the Crankshaft sensor circuit. (It didn't say whether it was upper or lower). Does anyone know whether these sensors supply an input into the computer that controlls ignition? Or to the tachometer? My tachometer is fine, but I have an occasional stalling problem. Generally the engine runs very smoothly, but it will stall at stoplights once every couple of weeks or so.
Ranger
06-06-06, 12:54 AM
I believe the sensors supply information to the PCM.
chevelle
06-06-06, 11:26 AM
The 2000 and later crank sensors are actually a bit of a hybrid in that they have electronics integrated into each sensor that processes the signal from the reluctor wheel teeth and sends that information directly to the PCM. Previous model year crank sensors were much simpler and sent the raw signal to the electronic ignition module under the coil pack for processing. Since the 2000 and later sensors send info directly to the PCM which controls the coil-near-plug ignition directly the signal processing is done inside the sensors.
Tach info in the car is sent from the PCM to the dash module in digital form over the serial data link so there is no direct connection at all with the crank sensors.
If you have a stalling problem with a 2000 simply replace both crank sensors. The service parts incorporate design changes that supercede the original parts to improve long term reliability. It is possible for the 2000 MY sensors to cause an occasional stall without setting a diagnostic code. With the code set the sensors are certainly causing the problem. Just replace them both with the upgraded service parts.
Astronomer
07-03-06, 11:30 AM
Does anyone know if GMPARTSDIRECT carries the latest higher quality sensors? I understand there are some off-quality sensors made in mexico and I want to be sure i get the correct sensors to elliminate the occasional stalling.
eldorado1
07-03-06, 12:37 PM
No eye deer.
Probably best to get them locally in case you need to return them. (assuming they let you)
GreenMachine
07-07-06, 12:02 AM
In the past year I've had this happen, started late winter, hasn't happened in about a month but during winter and spring it did it. It'll be fine, then I see the tech run to 575, it grumbles, engine stalls, gives me a code that just states engine stall detected. It will only happen at a stop, wont do it while driving. Usually occurs either when the car first stops for when I creep up and then stop.
Dadillac
07-07-06, 09:46 AM
I bought my sensors from them. I assume that they are the new updated parts, as they were visually different than what came out of the block. Since I installed them, I haven't had an issue.
Don
0to60n4.5
07-07-06, 09:15 PM
My 01' STS got to stalling every day on the way to work and again on the way home ( only 7 miles one way ).
It would stall in the middle of going down the road , not just at a stop. But it would always start right back up.
Bought both upper and lower CPS from Autozone and car hasn't stalled since ( about 5000 miles ago )
Astronomer
07-07-06, 09:47 PM
Thanks for the info guys. :worship: I have not had a chance to get under the car yet to see how much of a job it is to get at them. Is it right that I will have to remove the oil filter? Or; on the 2000 and newer are they reachable and serviceable without that hassle? My FSM (a good one from Helm, Inc.) is ordered and on the way, if there are good schematics I might be able to answer the questions myself....feel free to chime in if you have done this job yourself and have anything to offer in the way of advice.......... anyone?
Ranger
07-07-06, 09:58 PM
When I had mine done on my '02 SLS (warranty) it was on the rack for no more than :30 minutes, so it can't be too bad.
Dadillac
07-08-06, 12:31 PM
http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/72779-96-sts-crankshaft-position-sensors.html
Check out what I posted in this thread. It may be helpful.
Don
GreenMachine
07-08-06, 04:58 PM
Don
thanks for that link, will certainly come in handy, next time I change the oil I'll buy those and put them in. I'm sure if I go to the dealer and ask for the part it will be a bit more expensive but then I'll be able to say I need X for X car and get what I need the first time.
bmerrell14
07-19-06, 02:53 PM
when you replace both the uppers and lowers, do you have to do anything with the pcm to synch the sensors. In another thread a new member swore up and down if you do not use a CASE learn or bidirectional cable something that the new sensors will not work properly.
I am having the same problem on my 2001 deville
Ranger
07-19-06, 03:51 PM
I do not believe that there is any thing to be done other than R & R them.
Dadillac
07-23-06, 11:43 AM
The FSM shows doing this learn process. It basically is doing a WOT while in park (the computer will keep the revs to 4,000), and checking the tech scanner for a proper readout. All that I did, was the WOT, which the computer kept the revs at 4,000, and started driving the car. I have had no issues with this. I am confused as to what the learn procedure is for.
Don
