View Full Version : Cadillac catera help
compubud1168
06-03-06, 10:40 PM
I own a 2000 cadillac catera and for starters, I need help finding where the oil filter is? I cant find it. If anyone can tell me where it is I would appreciate it.. Also I have a problem with the car loosing coolant.. alot of it but I cant find it leaking anywhere. I hope this is not something major. If anyone can give me some insight on this I would appreciate it also.. Thanks
Richard K
Warez
06-06-06, 10:27 AM
Filter is located on the drivers side of the engine block righ under the exhaust manifold only accessible from under the car. Unlike the 97' and 98's, the 99+ used the canister type like that found on BMW's an most euro cars; not the conventional type. Just screw open the silver aluminum canister and replace the filter element. I initially did not know this as well and I was searching to no avail.
As for the coolant leak: check the heater control valve directly behind the plenum. I replaced mine about 3 weeks ago. Very common and luckily very cheap. I replaced mine in ~15 min.
compubud1168
06-12-06, 10:21 AM
can you tell me how to get to this heater control valve? I have no idea where it is or how to get to it?
