: 1992 305 Poor Start.
06-02-06, 12:38 PM
I replaced the intake manifold gasket because it was leaking coolant. When I got everything put back together, the engine just barely starts. It runs at about 300 RPM, and won't increase RPM. After about 30 seconds it stops. It has a bad odor.
I have checked and rechecked everything several times, but I can't find anything wrong.
Any ideas ? ?
06-02-06, 04:57 PM
Problem solved !
Although I had very carefully marked the position of the rotor before removing the distributor, and I thought that I had installed it exactly as it had come out, it had somehow ended up off by one tooth on the drive gear. I found this out with the use of a timing light and having my wife man the controls to turn the engine over.
I R & R the distributor, reset the timing, and it is now running perfectly.
