: how do I remove my drivebelt 1991 brougham
06-01-06, 07:29 PM
im trying to replace my water pump but i cant figure out how to adjust or loosen the drive belt. (theres only one) in my manual it says that each componet has two screws that loosen and adjust it, but I cant seem to locate any screws on any component that appear to help me loosen the belt without removing anything.
06-02-06, 09:21 PM
A half inch breaker bar is inserted into the square hole by the tensioner to pull back to relax the tensioner, then the belt just falls off. I'm a little concerned that you are replacing a water pump and cannot figure out how to remove a fan belt?
