Kaliwest84
05-28-06, 11:22 PM
Hey..i was thinkin of changing my fog light to a hyper white bulb..some what to match my HID headlights..how would i go about removing the fog light...will i have to take my grill off? to replace the bulb? thanx
| View Full Version : HID bulbs Kaliwest84 05-28-06, 11:22 PM Hey..i was thinkin of changing my fog light to a hyper white bulb..some what to match my HID headlights..how would i go about removing the fog light...will i have to take my grill off? to replace the bulb? thanx B Hoth 05-28-06, 11:44 PM No sir, just pull afew of the tabs off the front wheel fender well. This will give you direct acess to the fog assembly. The bulbs twist and pull out. I added the silverstars 9005XSST's. others have put in the stock high beam bulbs. A few members have talked about doing HID, but to date I have not seen that. This is a great upgrade that really is usefull on dark roads. Kaliwest84 05-29-06, 04:05 PM thanx..what about replacing the other bulb in the headlight...my top light is HID but the bottom bulb in my headlight isnt..how would i go abouts replacing this with a xenon bulb? (my question is ..how do i pull the headlight out?) pmpott 05-30-06, 08:09 AM are you talking about the high beam bulb or the little bulb in the corner? People have been replaceing the corner bulb with an LED. It's size 194 5 LED matrix bulb. Do a search and you can find links. BishopRuger 05-30-06, 08:14 AM If you are referring to the High beam that's best replaced with a silverstar or some other brand of Halogen bulb, HID's in your reflector high beam is overkill. Not to mention blinding to any oncoming drivers and it creates CRAZY glare. RobertCTS 05-30-06, 08:27 AM To replace the High Beam bulb you must drop the bumper. Here's a pic of the Fog/DRL from the rear. http://usera.imagecave.com/BobsWork/foginside.jpg Razorback_CTS 05-30-06, 11:23 PM That's a great picture Robert. It's not neccessary to remove the wheels is it? Razorback_CTS 05-30-06, 11:30 PM No sir, just pull afew of the tabs off the front wheel fender well. This will give you direct acess to the fog assembly. The bulbs twist and pull out. I added the silverstars 9005XSST's. others have put in the stock high beam bulbs. A few members have talked about doing HID, but to date I have not seen that. This is a great upgrade that really is usefull on dark roads. BHoth, where can I find that bulb on sylvania's website? B Hoth 05-30-06, 11:51 PM I went to Walmart, or got to pep boy's. The 9005 XSST will plug and play for both the high beams and the fogs. You can also do silverstar ambers for the daytime running lights and the rear turn signals. Those are 3157A ST's. All of these should come in 2 packs. You notice the difference the first time you are next to a CTS with the stock bulbs.(looking at the headlights) You'll definitley see the difference on the road. Razorback_CTS 05-30-06, 11:59 PM Thanks B RobertCTS 05-31-06, 05:11 AM That's a great picture Robert. It's not neccessary to remove the wheels is it? It's possible but not easy. I removed my wheels.:) BishopRuger 05-31-06, 07:59 AM Much much harder and WAY more work to remove the wheels. Totally unnecessary step & a hassle. When ur working on the left fender, turn the wheels to the right and vice versa when working on the passenger side fender. By turning the wheels u get access to all the needed push pins to remove the fender walls, its simple and easy. pmpott 05-31-06, 08:21 AM That's a great picture Robert. It's not neccessary to remove the wheels is it? You do not need to remove the wheels, you can just turn them all the way to one side (and then back the other way to do the other side). Removing the wheel will just give you a little more room to work with EDIT: oops, too slow RobertCTS 05-31-06, 09:06 AM I have a air impact wrench. A wheel can easily be removed in less than 30 seconds. If you're a big guy you will want to remove the wheels. And it gives you the opportunity to check your pads and rotors and maybe clean the back of your tires & rims.:yup: AznPrydeRegalRyde 05-31-06, 09:11 AM And it gives you the opportunity to check your pads and rotors and maybe clean the back of your tires & rims.:yup:Thats the main thing. Thats why I remeoved my wheels to change my fogs. :) My gf asked me why I needed to remove my rear wheels to changes the foglights tho...lol 050505songray 06-01-06, 05:24 AM hey anyone got any pics of the difference, i just bought a set of the silverstars for the fogs, puttin them in later just lookin for some pics of the difference thx pmpott 06-01-06, 07:51 AM someone posted pics a while back but I can't seem to find them. I replaced mine but I hardly ever use them because I like the look of my HID's more. They are so bright you could drive with just the fogs on (it looks like driving with your headlights on). But they are angled downward so they dont blind oncomming traffic 050505songray 06-01-06, 03:35 PM well this is what ill do. ill wait till the suns goes down a lil then ill throw one in and take a pic so everyone can see the difference. 050505songray 06-01-06, 03:38 PM oh yea one more question ..... anyone having trouble with them burnin up the wires???? had that happen to my old car when i threw in these lights, whats the specs on the stock ones, dont wanna run em if they are gonna f sometghin up, i always drive with mine on daytime and night, with the hid's oh yea anyone got the correct part number so i know i got the right ones | |
