: 83 Coupe Deville Fuel Pump Pressure?
05-23-06, 11:00 PM
Hi, i have an 83 coupe deville that had the HT4100 in it. I have purchased a 350 that came out of a 68 buick skylark. My question is, how much pressure does the stock fuel pump push out? And if it would even be possible, should i use the original fuel pump or the mechanical pump that is on the 350?
05-24-06, 06:13 AM
Use the mechanical pump on the 350. The 4100 is FI, 350 will be carb'd and probably need less pressure.
05-24-06, 03:55 PM
The 4100 used a fuel pressure regulator to control pressure in the 10 lb range. Without the regulator it can go to 3 times that! A carb'ed engine as you know, needs like 3 to 5 lb pressure. Use the mechanical pump.
05-24-06, 06:26 PM
Alright thanks guys. One more quick question though, am i going to be able to just hook the fuel line to 350 or will I have to drop the tank and remove or bypass the electric pump?
05-25-06, 09:20 AM
Anyone know?
05-25-06, 10:51 PM
?? I dont want to start a new topic on it
