View Full Version : lpe filter help please!!
ndogg ct
05-18-06, 06:03 PM
guys i took my intake off a while ago because of dealer service and i lost the directions..i am trying now to put her back on..
for the life of me i can't figure out where the steel sleeve goes??if i remember right it went into the maf into the screen ,but i can't get it to fit over the rubber piece in front of the screen??the steel sleeve then goes into the filter right??can anybody lean me the right way..thanks and yes i do feel stupid!!:confused:
heavymetals
05-18-06, 06:22 PM
Doesn't go over.
Is clamped by the connector piece on the filter,then there is a"reducer" that connects the ring to the MAF on the other side of the shroud.
StealthV
05-18-06, 06:32 PM
The steel sleeve goes on the airbox/filter side of the MAF right up to the screen like you are thinking. Then the short black hose from LPE fits over the sleeve, MAF end and the filter.
ndogg ct
05-18-06, 06:36 PM
so the steel sleeve does not go over the rubber that is over the screen??
does it just butt it??the lpe rubber piece then goes under the stock tubing and is clamped with the stock clamp??
damn i did'nt think it wasa this hard the first time that is why i want to make sure i am not leaving something out??so there is nothing that has to be removed from the stock tubing??
StealthV
05-18-06, 06:42 PM
Do not reuse the factory rubber MAF end that goes to the factory airbox.
Butt the steel tube up to the MAF screen. The LPE hose goes over the steel tube and end of the MAF. Secure w/ 2 clamps. The "free" end of the steel tube goes through the air divider wall and into the filter.
Crude sketch
MAF steel tube Filter
ndogg ct
05-18-06, 07:43 PM
yea i guess i forgot to tske the rubber piece over the screen off..now it looks so easy!!damn i feel dumb!!thanks guys!!
r_casino
05-18-06, 08:35 PM
The instructions are on the LPE site if you need to take a look...
http://www.lingenfelter.com/pdf/cadillac%20cts-v%20airbox%20installation%20manual%20v1.0.pdf
