View Full Version : How do ya check diagnostics on '95 FWB?
jc95fwd
01-26-04, 12:57 PM
Lately, I am getting a "Check Engine" light occasionally and don't have a clue why; everything seems to be running fine. How do you check the engine diagnostic codes on a '95 Fleetwood Brougham? I turned the ignition to "on", pressed "off" and the warmer arrow in for at least three seconds but that didn't seem to work???
DaveSmed
01-26-04, 02:28 PM
I know that you have to scroll through different systems, that it's not automatic. I'll move this into the Fleetwood section, so someone can give you a better answer.
jc95fwd
01-26-04, 06:04 PM
Oops; I later found out about scrolling through the systems... Does anyone know what a code of 126 in the HVAC system (02) means?:confused:
FASSTWOOD
01-26-04, 08:10 PM
26 is the dtc code the 1 in front of it means that it was a stored code
in the book it says
serial data communication (circuit shorted to B+,shorted to ground, or open circuit)
this is a post from the impalssforum hope it helps!
Come on guys... Let the car tell you what the problem is. Remember you are driving a Fleetwood!!!
With the car running, hold the "OFF" and "Temp Up" buttons down at the same time for about 5 seconds. This will bring up a segment check and then take you into computer "00" (PCM) diagnostics.
Now press the "Out Temp" button and record any codes. If you see a code prefixed by a "1", this is a history code.
Use the "Warmer" button to move on to computer "01" (CCM) and repeat the procedure.
Continue through the last 3 computer systems... 02=HVAC, 03=SIR, 04=ABS/TC
If you don't have "the book", let me know what codes show up and I'll give you the run down.
Oh yeah, if a code is being displayed, you can select the "OFF" button to instantly clear that code from the system. This will get rid of any intermittent problem and get those lights off of the dashboard. If the problem is real, the code will be set again and the lights will come back on.
VIN Guy
01-26-04, 08:48 PM
On that particular code, if it is a current code (active, meaning the PCM is not getting a signal from HVAC controls), then your AC compressor will run all the time. If it just lost connection in the past, and the connection is currently working, I'd clear the code and see if it returns. If so, you've got a short, or a bad HVAC control most likely.
jc95fwd
01-27-04, 09:46 AM
Thanks alot for the info. I cleared that code and will see if it ever returns. Now this morning I had the check engine light come on for a while again, but when I went to check the diagnostics what I got was: in the 05 category (is there such a section) there was initially a 161, then a 163. Any idea what the heck that means?!
FASSTWOOD
01-27-04, 11:30 PM
that might of been engine temp. I gotta check but i left my manuals at work
get back to ya.
jc95fwd
01-28-04, 09:32 AM
get back to ya.That makes sense; thanks. Off the topic, but do you know what the diameter size is for the muffler inlet/outlets and if they are both offset or on is in the center? I'm gonna order the Summit Turbo mufflers and could of course just go out and lay on the ground and look/measure, but here in Cincy right now it's 10 degrees with about 6" of snow on the damn ground!
FASSTWOOD
01-28-04, 09:41 PM
Check here...dyomax (http://www.dynomax.com/documents/passenger/general_motors.pdf) I thinks its 2 1/2 offset offset :Offtopic:
