LA Bean
05-17-06, 05:32 PM
is it possible to put the oem 03-05 side mirrors on my 02 escalade ext? does it fit perfectly in? is the install for the power on the led going to be easy?
| View Full Version : 03-05 side mirrors on 02, is it possible? LA Bean 05-17-06, 05:32 PM is it possible to put the oem 03-05 side mirrors on my 02 escalade ext? does it fit perfectly in? is the install for the power on the led going to be easy? slk230mb 05-17-06, 06:43 PM JPCustoms makes replacement glass for the 02s that addes the LED turn signal. You just have to replace the glass and run 2 wires to the turn signal resistor. It's probably just cheaper to replace the glass. http://www.jpcustoms.com/store/customer/product.php?productid=16352&cat=353&page=1 whereismyescalade 05-17-06, 06:58 PM I put these on my '02, I love them because they turn on when I am in reverse or have the brakes on. I have seen others than only come on when you turn. They're easy to install if you have some know-how. http://www.kwmuth.com/ slk230mb 05-17-06, 08:51 PM Those are the same as the ones from JPCustoms :thumbsup: LA Bean 05-17-06, 09:07 PM is this easy to install? im not good at this kind of stuff. does the mirror replace the old one or is it attached to the old one? R1stunta 05-18-06, 05:59 PM Do these new mirrors still have the functions like the OEM ones such as the heated feature and the dim feature? Thanks! | |
