View Full Version : Huge Problem Please Help Now Fast! AdnanBomova 05-17-06, 12:02 AM alright i had to change my starter! i changed the starter and i think i put everything back in its place! anyway as i started the car ( started perfect) its reving at high as RPM and i get the check engine light on ( it sounds super charged) and everything is like moving faster/louder than usuall! i pulled the codes ( PO22 CURRENT, P052 HISTORY, P109 HISTORY, IO27 HISTORY, IO52 HISTORY, SO11 HISTORY, SO16 HISTORY) then i try to move the car ( put it in reverse and the car moves fast as hell back) and i hit the brake the stop it and it doesnt work, so i put it in park right away! i try again and the same thing happens! iam realllly ****ing pissed, please help asap thanks in advance AdnanBomova 05-17-06, 12:05 AM P022 (E022) .................................................. Open TPS Signal [VCC]
P052 (E052) .................................................. ..... PCM Memory Reset
P109 (E109) ....... Keep Alive Memory (KAM) Reset/PCM has lost primary battery power
I027 .................................................. ...... PRND321 switch failure
I052 .................................................. ..... Keep Alive Memory Error
These both dont mean anything ( i changed the struts w/ aftermarket)
S011 ......................... Left Front Damper Solenoid Valve Short to Ground/Open
S016 ........................ Right Front Damper Solenoid Valve Short to Ground/Open AdnanBomova 05-17-06, 12:06 AM wow, i cant believe this crap, i hope i didnt mess up my engine! iam soo mad at myself! i just wanted to change my starter! shit iam pissed! WOTMODE 05-17-06, 01:33 AM I'll bet you pinched something under the intake manifold, causing huge vacuum leak. well I just changed my starter two In my 99 sts, I too have problems I am tring to deal with, I was looking at your codes and noticed there different than mine.
did plug everything back in?
not shure if the 95 and the 99 have the starter located in the same place or not, but if its like mine. I am thinking that mabee the gasket is not seated right, or that it may be getting air because the bolts are either to loose or too tight, I read 7.4 in another post was the right post?
hope this helps you, in either case I dont think the problem is too big. AdnanBomova 05-17-06, 09:57 AM well I just changed my starter two In my 99 sts, I too have problems I am tring to deal with, I was looking at your codes and noticed there different than mine.
its the same thing/place for the 99! does anyone know what i can do? help please, i need to drive to work today zonie77 05-17-06, 10:52 AM You probably have a vacuum leak. Take the intake off and check the gasket. Make sure it's in place and not twisted or anything. The bolts take a low torque setting so don't overtighten. AdnanBomova 05-17-06, 11:02 AM You probably have a vacuum leak. Take the intake off and check the gasket. Make sure it's in place and not twisted or anything. The bolts take a low torque setting so don't overtighten.
i took the intake off again and i saw a sensor was not put it, so i plugged it in and checked everything again and nothing is twisted or misplaced! now i got a p105 error and as soon as i started the car it said SERVICE VECHICLE SOON AdnanBomova 05-17-06, 11:04 AM P105 (E105) ........................................... Brake Booster Vacuum Too Low
this would explain why the brakes dont work when i put the car in netural/reverse AdnanBomova 05-17-06, 11:06 AM You guys are my only hope! if this doesnt work, iam going to have to do the unthinkable and tow it to the mechanics ( which i dont want to do) CadillacSTS2003 05-17-06, 12:06 PM clear all the codes for shits and giggles and then start the car see what codes come back on.
check your brake fluid and fill it if necessary then pump the brakes up to ensure good pressure AdnanBomova 05-17-06, 02:20 PM alright guys, i fixed it and its running perfect! there was a couple of loose/unpluged lines....everything plugged in and its running sooo ****ing good! i just came back from the mechanic who charged me 700 bucks for it, and i asked him of how good a job i did! i love you guys! thanks for everything! THread CLoseD CadillacSTS2003 05-17-06, 02:26 PM ouch 700 bucks damn makes you wish you would of had them do the starter install probably wouldnt cost as much |
