johnpage
05-16-06, 07:49 PM
my 2000 sts trunk and fuel door open when ever they want to ck. the fuse disconected the batt. -still doing it took the fuse out .anybody been there.thanks john p.
| View Full Version : possessed johnpage 05-16-06, 07:49 PM my 2000 sts trunk and fuel door open when ever they want to ck. the fuse disconected the batt. -still doing it took the fuse out .anybody been there.thanks john p. CadillacSTS2003 05-16-06, 08:17 PM your buttons are probably stuck inward try pushing them un and out a couple of times then maybe use some compressed air or maybe even wd-40 free it up. MacKiNBacK 05-17-06, 02:01 AM I also noticed when I battery was starting to go bad the trunk and mainly fuel door would open on their own. MacK Dooman 05-17-06, 07:53 AM The sunroof drain on my 99 was leaking down the A pillar to my dash, causing the same symptoms. The water was shorting out my switches and i never seen a drop. I finally figured it out and reconnected the drain and has been perfect since.. | |
