Tailfin
05-16-06, 01:04 PM
Ok, this little issue is still bugging me... Basically, after the engine's all warmed up, and I'm cruising along, and a slight slope comes in the road, I press the pedal down a little bit (without downshifting), and I hear this gutteral sound from the engine. The sound is very tricky to describe... But it sounds very close to when your exhaust starts to leak. It goes away if I push it to downshift. I know these are EGR conditions, but I replaced the valve and the solenoid, and the tubes are clean, throttle body and intake all nice and clean... Basically no shady parts in here... Everything seems to be running fine, but this noise is bothering me.
I also noticed the same noise when I had my 85 Sedan Deville. It was definitely the same noise, but worse on that thing (drove me mad). Also, on the 85, I noticed the noise would go away after an oil change, but be back within a week. The main bearings were done on that car, so I don't think it's related to that. So my only theory on this is a weakening oil pump? Anyone know?
