View Full Version : 95 SLS Very Low Refrigerant - Help!
dboncio99
05-15-06, 11:33 PM
OK, I have had this problem before and have searched the forum for answers. I have tried to clear this message, I have tried filling the system with the 134a as required. I cannot get the compressor to switch on and I have tried to by pass the pressure switch. I am out of ideas, what have I missed? I was able to get past this last year, I thought!:confused:
WOTMODE
05-15-06, 11:48 PM
How much freon did you put in? Might need to evac. and recharge to make sure freon level is correct. Try clearing any codes the car has stored.
Ranger
05-16-06, 12:49 PM
Your car uses R12, not R134a........... unless it has been converted.
94greencaddysls
05-16-06, 01:40 PM
I thought 1993 and earlier vehicles used R12, No?
dboncio99
05-16-06, 03:03 PM
MIne is posted 134a right on the drier. Don't think it was ever converted, looks to be originl GM tag.
dboncio99
05-16-06, 03:06 PM
I have also truied to clear the codes but the message will not clear. I have heard it may require me to disconnect battery, i this correct? Can't you just use the on-board system? Of course thatdoesn't seem to b working for me!
Dino1956
05-16-06, 07:24 PM
I have the same problem with my 1990 Seville. I just got it filled with R-12 and the message still comes on even after clearing computer codes & disconnecting the battery. If you disconnect battery, you may be able to use the A/C and then the "Low AC Refrigerent" message will come on for about 2 weeks until the Compressor finally shuts off. I've had this message for the 5 years I've owned the car. My Freon R-12 level is 40% Pressure which the mechanic told me is the correct amount. The same amount is in there that was put in 2 weeks ago. Nothing leaked out. He even said my AC looked like it was in good condition. There is definitely a Ghost In The Machine.
Ranger
05-16-06, 08:39 PM
Well, I thought that the switch over from R12 to R134a was '96.
If you guys are clearing the codes correctly, and the system is verified full with no leaks, then perhaps you have a bad low pressure switch or a poor connection to it.
dboncio99
05-17-06, 06:18 PM
Well, I got through this last night. The code for the "very low refrigerant" is in the APC list and each seperate list, PCM, APC, TPC etc must be cleared individuall, which now I know. Once I cleared this the compressor came on and I could add the refridgerant no problem, Cold A/C again! THanks for the help!:thumbsup:
rollman
05-22-06, 04:43 PM
Just for the record my 94 STS has the same sticker .134A
Dino1956
05-25-06, 06:59 PM
dboncio99,
I thought you only had to clear the error codes that flash at the beginning of diagnostics. Are you saying to go into each setting in APC and clear codes ? I'm confused. Mmmmm...
Dino
Ranger
05-25-06, 07:53 PM
Correct
