View Full Version : StabiliTrak stability enhancement system
Platinum06
05-14-06, 09:40 PM
So how can I dissable this?:stirpot:
The Traction control off does not cancel this out....rather intrusive since you get the thing sideways and it kicks on.:tisk:
kali_cts03
05-14-06, 09:44 PM
Hold and press the T/C button for about 5 seconds, it will then display on the DIC that it has been disabled....
050505songray
05-14-06, 09:45 PM
can u have both stabilitrak and the tc off ?
jteolis
05-14-06, 09:48 PM
Yeah
050505songray
05-14-06, 09:49 PM
lol never knew that, uh oh there goes the license lol
kali_cts03
05-14-06, 09:50 PM
if you just hit the t/c button - it will only turn off the t/c
if you hold it it will turn off both
if you press it again it will bring both on
ChicagoCTS32
05-14-06, 10:23 PM
It only works with the button inside the glove compartment... it does not work for the programmed presets.
Platinum06
05-14-06, 10:52 PM
I see
Platinum06
05-14-06, 10:53 PM
I see....:thumbsup:
kali_cts03
05-14-06, 11:34 PM
section 4.10 of the 03 manual explains it all.... :)
bigsef36
05-15-06, 12:50 PM
Nice, I need to try that myself :)
TagApl4
05-15-06, 03:04 PM
:banana: Oh Good To Know!!! There Goes My Rear Diff! :spin: :burn:
axnguyen
05-15-06, 07:12 PM
My stability system is screwed up right now - keeps engaging for no reason. The dealer isn't sure what the problem is (they're guessing a steering wheel sensor) but I asked him to disable the Stability for now until the part comes in.
He took out the steering wheel sensor which disables the whole Stability control system...I like it :D
Ilyesha
05-15-06, 10:23 PM
It is the sensor in the steering wheel. Many of us had this same problem, including me.:want:
nicrdh
05-15-06, 11:19 PM
I having the same problem, My dealer can't find anything wrong. It goes off every 5 mins on the highway. No error codes were found, so they have no idea. I suggested the steering position sensor since so many others have had that problem, but they said they cannot replace anything without an error. I am starting to get pissed. I only have this issue at highway speeds so they can't observe the problem with the local test drives they have been taking, I am trying to get them to take it for a 65-70 mph cruise.
