: oil filter adapter
05-14-06, 05:14 PM
I see that there was a change in part#s in mid 97 for the oil filter/cooler lines adapter that mounts on side of block.
I broke one on the 95 and need a replacement.
Just wondering if the change was only due to increasing the pipe thread hole for oil pressure sensor. (it changed from 1/4 to 3/8).
Anyone got a good one?
05-23-06, 01:31 PM
I went thru serious drama with that part on my 94.. but yes you're correct. The 2 differences that came up were with/out oil cooler holes and the plus sized thread for the pressure sensor.
05-23-06, 10:27 PM
Yea I found one thats the supeceded part.
Has the cooler line tapped but the oil pressure sensor hole is tapped to 3/8.
I just added a 3/8-1/4 threaded bushing and all is well.
I also found one in a JY that has only 1 tapped hole for oil cooler lines,with a threaded plug in it,and the other boss isnt drilled or tapped.
