View Full Version : Cutout template for 3.2 bumper (V exhaust install)
roman371
05-13-06, 08:41 PM
I will be installing a V Exhaust on my 3.2. Does anyone have a link or want to part with a template that can be used to trace and cut out the right-hand bumper skirt? Thanks!
dup's Cadi
05-13-06, 09:02 PM
I might still have it, I'll have to check to see.
roman371
05-13-06, 09:05 PM
Thanks,
Did folks that did this let the exhaust shop do the work, or do it solo?
kali_cts03
05-13-06, 09:09 PM
Thanks,
I had the whole thing done at the muffler shop, they did a pretty damn good job.... write up on Reeds FAQ site of my swap!!! :thumbsup:
FlyFlip420
05-14-06, 12:59 PM
Done by myself with a dremel tool
roman371
05-14-06, 04:40 PM
Did you trace it from the other side, or have a template? Also, which dremel attachment did you use, the cutting blade that is about the size of a dime? Any issues? Thanks
FlyFlip420
05-14-06, 08:40 PM
Well my car has a rear fascia over the original bumper....the fascia had a cutout from the factory for the second exhaust so all I had to do was follow that....I used a cuting, sanding bit...it looks like a drill bit.........but if you trace the other side, and put it up and cut it out, you will in essence have the same thing
roman371
05-14-06, 10:05 PM
Got it. That helps, thanks alot.
dup's Cadi
05-15-06, 08:06 AM
Did the same. Can't find the template.
bigsef36
05-15-06, 10:13 AM
Great tips guys
