View Full Version : Fuse Box loacation?
sbuscha
05-13-06, 11:51 AM
Could someone point me to the fuse box. I was attempting to install my bright white lights and blew a fuse. Now my dome, door and under dash lights are out.
I am so frustrated. I went to superlumination and ordered the lights. 3 out of 4 of the 44MM Festoon lights do not work....agh!! On top of that I blew a fuse
Mbai2
05-13-06, 03:14 PM
The car has 3 fuse boxes. There's one under the hood and two more under the rear seat cushion. The fuse that you most likely burned up is located in the passenger side rear seat fuse box. It will be labeled "INTERIOR LAMP".
To access the box, pull up firmly on the front edge of the passenger side rear seat cushion until it pops up. Then pull up firmly on the driver side until it pops up. Lift up the entire cushion and you will see two fuse boxes underneath the carpet in front of the seating area.
sbuscha
05-13-06, 03:24 PM
Thank you!!
